Introduction: How to Use a Few Pieces of Wood to Assemble Into a Cute and Powerful Wood Robot Arm
- The name of the robot arm is WoodenArm. It looks very cute!
- If you want more detail about WoodenArm,please refer to www.lewansoul.com
- Now we can make an introduction about the WoodenArm, let's move on it!
Step 1: Description
LewanSoul-WoodenArm is a wooden robotic arm with powerful performance based on Arduino Nano board. The mechanical structure of the entire robotic arm is made of pure wood. Its appearance is exquisite and compact, and its structural stability is strong. The main control chip it used is the Arduino Nano board. The output is the LFD-01 servo, which can connect multiple modules at the same time. A variety of interesting games can be created based on different sensor modules.
Step 2: Getting to Know the Parts
This cute WoodenArm has various electronic modules: Acceleration module ADXL-345, Color module APDS-9960, Rotary knob module, LED Display screen, LDF-01 servo.
Besides, based on the Arduino Nano control board, we have developed our own Arduino expansion board in order to have more functional modules, and then using WoodenArm to realize more creativity, better learning programming and experience in the process, bring us happiness. So intelligent WoodenArm has the ability to achieve different gameplay.
Step 3: Body Assembly_1
Required materials:
- Robotic arm body bracket*1
- LDF-01 servo*1
- Screwdriver*1
- Screws* several
You need to install a part of the body as shown in the picture. It is only necessary to fix the small blocks with screws, and then use screws and servos to fix them together. During this process, pay attention to adjusting the tightness of the screws. Pay attention to adjust the tightness. This process tests the hands' ability of 3 stars.
Step 4: Body Assembly_2
Required materials:
LDF-01 servo*1
Screwdriver*1
Screws* several
Only need to fix the small block with the corresponding screw, and then Use a screw to connect the servo and the block and fix it, and then fix the servo and the block together. Pay attention to adjust the tightness. This process tests the hands' ability of 2 stars.
Step 5: Body Assembly_3
Required materials:
- LDF-01 servo*1
- Screwdriver*1
- Screws* several
You need to install a part of the body as shown in the picture. This part is a bit simpler than the previous part. It is only necessary to fix the small blocks with the corresponding screws, and then install them together with the servos assembled in the previous step. Pay attention to adjust the tightness. This process tests the hands ability of 3 stars.
Step 6: Claw Assembly
Required materials:
- LDF-01 servo*1
- Screwdriver*1
- Screws* several
You need to install the claws as shown in the picture. Only need to fix the small wooden block with the corresponding screw, and then use the screw to connect the servo and the wooden block and fix it, and then fix the servo and the small block together.
Pay attention to adjust the tightness. This process tests the hands' ability of 4 stars.
Step 7: Chassis Assembly
Required materials:
- Dupont line*4
- Screws* several
- Nylon*4
- Rotary knob module*4
- Arduino Nano control board*1
- Expansion board*1
You need to install the chassis as shown in the picture. This part is to fix the rotary knob module to the base with screws. At the same time, it needs to insert the Dupont line on the rotary knob module. Finally, the Arduino Nano control board and Arduino expansion board are screwed in the middle of the four rotary knob modules. This process tests the hands' ability of 4 stars.
Step 8: Integral Assembly
Required materials:
- 30cm Winding pipe*1
- Screws* several
- Sucker, washers, gaskets, nuts*1
- Rolling belt*4
Congratulations, you finally arrived at the final step of the installation. You need to install the rest as shown in the picture. In this step, you need to fix the previously installed base and arm sections together so that you can become a complete WoodeArm. This process tests the hands' ability of 3 stars.
Here is the website of WoodenArm assembly video:
https://www.youtube.com/playlist?list=PLQYW5Ukp-1D-4u2Z8CBjoQ4pSFhfnP74B
Step 9: Design Considerations
Step 10: Gameplay & Final Remarks
You can use the computer or infrared remote controller to control the Wooden Arm.
You can insert the program into the Arduino Nano control board to control the WoodenArm. You can also modify the program or even create a new one by yourself. In fact, in order to help users better learn about WoodenArm development kit, we have prepared several interesting gameplay for users, helping them to quickly get started with WoodenArm learning(You can refer to our LewanSoul website ).
The next game is waiting for you to create~
Join us soon~
Have fun~
