How to Use a Sand Blaster
Intro: How to Use a Sand Blaster
A sand blaster is a fantastic tool for preparing parts for operations such as powder coating. It can remove rust, paint and other surface imperfections. It can also be used for aesthetic purposes, like sandblasting glass in particular designs.
This instructable is strictly to show practical operation of a sand blasting unit and is referenced in Powder Coating Basics.
I made this at TechShop Detroit (www.techshop.ws).
STEP 1: Assemble Power Head Components
Generally these components are stored separately and assembled when necessary. The main components are the power head, the nozzle and the siphon air jet.
Insert the nozzle into the power head and secure it. In this case, using an allen key.
Next, insert the siphon air jet into the power head such that the gasket is visible.
STEP 2: Attach Power Head Assembly to Gun
Open the sandblaster and insert the gun into the power head assembly, ensuring that the siphon air jet is still in place.
Secure the connection, in this case using a wrench on the bolt.
STEP 3: Attach the Siphon Hose to the Power Head Assembly
Within the sandblasting cabinet, attach the siphon hose to the bottom inlet of the power head assembly. The siphon hose supplies the media (generally sand) to blast.
STEP 4: Put Components for Blasting Into the Cabinet and Secure Cabinet
Put the parts you wish to sandblast into the cabinet.
Then close the door and ensure that the door mechanisms are securely fastened.
STEP 5: Complete Preparation for Sandblasting
In this case, turn on the light in the cabinet and turn on the fan. The fan is a separate switch for the room and is near the room light switch at TechShop Detroit.
Optionally, you could can turn the room light off for a better view inside the cabinet.
STEP 6: Turn on Sandblaster
The power switch on the left side of the cabinet.
STEP 7: Insert Your Arms Into the Gloves and Position on Foot Pedal
Insert your arms and position yourself so that you have a clear view into the cabinet. Position your foot in the foot pedal mechanism. Once you depress the pedal the media (sand) will blast from the gun.
STEP 8: Sandblast Your Components
Pick up the gun and the parts and manually aim where you need to clean. Keep your strokes smooth and make sure to blast all edges, including the sides.
STEP 9: Remove Components
When finished, turn off the machine, open the cabinet and remove the finished components.
STEP 10: Remove the Power Head Assembly
In the reverse of the manner in which you attached the power head assembly, disconnect the siphon hose and remove power head from the gun.
STEP 11: Disassemble the Power Head Assembly
Remove the siphon air jet and then disconnect the nozzle.
Fin.
Fin.
2 Comments
CharlesL25 8 years ago
That's not a sandblaster that is a bead blaster cabnet
DaveyH 9 years ago
I could really learn to use one of these. I build little metal sculptures and paint them over, but have to pay to get them sand blasted. I think it would be much easier if I could just blast them myself. Thanks for the instructions. I'll have to get a sand blaster first before I make another one. http://www.burwell.com.au/catalogue/blastrooms/burwell-enclosed-blast-facilities
blast rooms
Target Vertical:
Construction & Contractors
Link:
Our system matched the above Link to your Targeted Keyword. If you feel it is not relevant, please click the 'Delete' button below and we will generate another Action for you.
Write Content:
Insert KeywordFind KeywordLink Selected TextInsert Customer URLCopy
Load Link
Skip Customer
Cancel Delete Complete
You are here: Specialist Workspace Keyword Link Building
