Introduction: How to Use the FC-37 Rain Sensor With an Arduino
Hi! In my first instructable I will show you how to use the FC-37 rain sensor with an arduino. I am using an arduino nano but other versions will work just fine!
Step 1: Things You Need:
1x -- FC-37 and its controller board.
1x -- Arduino
1x -- Green Led
1x -- Red Led
some jumper wires
Step 2: The Wiring
So to connect the FC-37 and the LEDS to the arduino follow these steps.
5v ------------ VCC (controller board)
GND ------------ GND (controller board)
A0 ------------ A0 (controller board)
You do not need to use D0 on the controller board.
Now on the other side of the controller board there are two pins. You have to connect them to the FC-37. You can connect them in any direction, It doesn't matter. There is also a potentiometer on the controller which adjust sensitivity although you don't have to mess with it to get it working.
and for the LEDS
D2 ------------------ positive of the RainLED (in my case a red one)
D3 ------------------ positive of the DryLED (in my case a green one)
GND ------------------ negative of both LEDS
Step 3: The Code
This is the .ino that you need to get it working.
Step 4: Preview
Alright if you did everything well it should work something like this! Just be careful not to fry the arduino if you replicate this!
