Introduction: How to Use the NonBlockingModbusMaster Library
Why this project? Version 2 of the Solar Hot Water Battery, uses two modbus devices to measure the 3 phase power and hot water kWhrs. It takes six (6) modbus commands to collect the complete system state.
These six commands take between a half to three quarters of a second (0.5s to 0.75s) to complete, assuming there are not timeouts. This library allows those six commands to be executed as a single block while still letting the loop() continue run at high speed to handle push button inputs and Serial commands. If one of the block's commands times out, this library also allows that command to be retried before continuing with the other commands.
The NonBlockingModbusMaster library has the following features:-
– With suitably sized serial TX and RX buffers, it is completely non-blocking.
– No callback methods are necessary for single command non-blocking use.
– Uses RTU modbus and works with any Arduino Stream object
– Supports multiple device IDs.
– Has a simple command chaining facility to group commands together in a single executable non-blocking block.
– Has a retry() method for use when the command times out (or other some other error occurs)
– Has oneTimeDelay() method to insert an extra pre-command delay. e.g. when switching between device ID's
– Supports optional results processing functions that are called when the command completes.
– Runs on UNO with software serial while maintaining responsive Serial and other loop() processing.
This tutorial uses an UNO and Paul Stoffregen's AltSoftSerial library. For an ESP32 example using Serial1, see the Solar Hot Water Battery Ver 2 project (under construction). To access Modbus devices with this library an RS232 to RS485 converter is necessary.
This library is a modification of the Doc Walker's ModbusMaster library.
Disclaimer:The readHoldingRegisters method is the only modbus command that has been extensively tested, due to lack if other modbus hardware. All other commands are expected to work as their code has been inherited from the original ModbusMaster library. Code corrections and/or test results welcome.
This tutorial is also available on-line at Non Blocking Modbus Master Library works with any Stream object
Parts List
Hardware
Arduino UNO ~US$27.60 or any other board supported by the Arduino IDE. All the code developed here can be tested with just an Arduino UNO.
RS232 to RS485 converter e.g.
Recommended (Isolated) TTL to RS485 Converter 3.3V/5.0V Hardware Automatic Control Converter Module For Arduino ~US1.00 aliexpress OR
(Non-Isolated) MAX485 TTL to Turn RS485 Module Level Conversion 485 To Serial UART MAX485CSA RS-485 For Arduino DC 3.3V 5V ~US$0.30
Some modbus device to test with. Here a JSY-MK-193 (~US35.70 aliexpress) power meter was used.
Software
Install the Arduino IDE V1.8.9+
Install the NonBlockingModbusMaster library from the Arduino Library Manager or from this NonBlockingModbusMaster.zip file
Install the Paul Stoffregen's AltSoftSerial library from the Arduino Library Manager
Install the SafeString library (V3+) from the Arduino Library Manager, it includes the millisDelay class and the loopTimer classes used here.
This library.zip file contains all the libraries needed for this tutorial. Rename your existing library directory and unzip this one to your Arduino Sketch directory OR use the Arduino library manager to download and install the libraries listed above.
Step 1: A Single Command NonBlockingModbusMaster Sketch
The first example sketch, UNO_modbus.ino, initializes AltSoftSerial and the NonBlockingModbus Master object and then calls readHoldingRegisters on slave ID 1, Address 0 for 4 registers every 3 seconds. The loopTimer records how fast the loop() method runs while the time to execute the modbus command is also output.
A sample output is
if (samplingDelay.justFinished()) {
samplingDelay.restart();
// readHoldingRegisters will return false and be ignored if nbModbusMaster is still processing the last cmd
// i.e. if nbModbusMaster.isProcessing() returns true
if (nbModbusMaster.readHoldingRegisters(slaveId, address, qty)) {
// cmd started
start_ms = millis();
} // else still waiting for last cmd to finish, skip this sample
This shows that the readHoldingRegisters command takes about 43ms to execute, while the loop() method runs at least every 1.2ms (1216us i.e. 40times faster) and on average runs every 8us. The max sofar of 5.4ms is due to running setup() initially. NonBlockingModbusMaster keep the loop running as fast as it can.
The sketch uses a millisDelay non-blocking delay timer, samplingDelay, to start a modbus read every 3 seconds (and restart the delay for the next read).
// cmd started
Each of the main modbus commands first checks that a command is not still being processed. If the modbus system is idle (isIdle() returns true) then the next command is started and the readHoldingRegisters returns true. If not then the command is not started and readHoldingRegisters returns false.
Once a modbus command has been started, then at some time in the future nbModbusMaster.justFinished() will return true, just once. This is similar to how the millisDelay class works. When nbModbusMaster.justFinished() returns true then the command has completed OR an error has occurred, so first check the getError() method.
if (nbModbusMaster.justFinished()) {
// check for errors
int err = nbModbusMaster.getError(); // 0 for OK
if (err) {
// … handle error
} else {
// process result
for (int i = 0; i < nbModbusMaster.getResponseBufferLength(); i++) {
nbModbusMaster.printHex(nbModbusMaster.getResponseBuffer(i), Serial); Serial.print(" ");
Serial.println();
What else can slow down your loop() code
Apart from delay's, which you should replace with non-blockingmillisDelay calls, Serial output can also slow down your loop(). The print statements block if there is not enough space in the Tx buffer to output all the chars. See Arduino Serial I/O for the Real World for how to avoid these problems. The NonBlockingModbusMaster also writes its commands to a serial connection connected to the RS232 to RS485 converter. So to avoid blocking in the NonBlockingModbusMaster library code, make sure the TX buffer size of the serial connection you are using is large enough to take the entire modbus command. For the modbus responses, the RX buffer size should also be made large enough to take the entire response. This is to ensure you will not lose any response data if the loop() code is slow in calling nbModbusMaster.justFinished()
The AltSoftSerial buffers are 68 bytes for TX and 80 bytes for RX. Increase these in AltSoftSerial.cpp if you need to. The ESP32 has 128 byte buffers by default.
Step 2: Retry Method
When you process the results, you have the option to retry() the command if it fails, typically due to a timeout. The UNO_modbus_retry.ino sketch illustrates this.
static int retryCount = 0; // the value of this count is kept from call to call
// check for errors
if (err) {
if ((err == nbModbusMaster.ku8MBResponseTimedOut) && (retryCount < MAX_RETRIES)) {
retryCount++;
nbModbusMaster.retry(); // send same cmd again
} else {
retryCount = 0; // success
if (!err) { // print results
Serial.println();
Calling retry(), starts the command again and suppresses justFinished() from returning true. That is, justFinish() continues to return false as long as retries are executing and only returns true after the last retry has completed or timed out.
Removing the 12V supply to the modbus slave device gives this output
The previous command completed at 00:453. The next readHoldingRegisters command was started 3sec later at 03:412 and timed out after 2secs at 05:412 and was retried.
The 3sec timer timed out again at 06:415 and tried to start the next readHoldingRegisters command but the system was still process the retry, so the readHoldingRegisters was not started and returned false, so printing the “skipped” message and the command start time was not reset. When the retry timed, at 07:417 out 2sec after the second attempt at the command started, the cumulative time for that command was 4sec (two timeouts) and it was not retried again.
Debugging the NonBlockingModbusMaster Library
At the top of the NonBlockingModbusMaster.cpp file you can uncomment the DEBUG_SERIAL define to send debug output to Serial.
Step 3: OneTimeDelay
The NonBlockingModbusMaster library provides a oneTimeDelay() method which adds the specified ms delay to the preDelay time for the next command only. This can be necessary when switching between different devices. For example when switching between reading a JSY-MK-193 on ID:1 and reading a JSY-MK-345 on ID:2, a 50ms delay needs to be added between the last ID:1 command completing and starting the first ID:2 command. Otherwise the ID:2 command times out. Simply add a call to oneTimeDelay() before calling readHoldingRegisters.
This extra delay is cleared when the next command's preDelay has completed.
Step 4: Processing Results With a Processing Method
As has been shown above you can process the results in the justFinished() block. However you can also specify a processing method to be call after the command completes, but before justFinished() returns true. The UNO_modbus_processing.ino sketch illustrates this.
void processData(NonBlockingModbusMaster &mb) {
Serial.println(" in processData()");
// check for errors
int err = mb.getError(); // 0 for OK
if (err) {
retryCount++;
mb.retry(); // send same cmd again
} else {
if (!err) {
for (int i = 0; i < mb.getResponseBufferLength(); i++) {
mb.printHex(mb.getResponseBuffer(i), Serial); Serial.print(" ");
Serial.println();
void loop() {
nbModbusMaster.readHoldingRegisters(slaveId, address, qty, processData); // add processing fn
Serial.println(" Finished.");
Basically the processing code from the justFinished() block is moved to its own method and that method name passed when calling readHoldingRegisters. NOTE: The result data and modbus errors are still available to the justFinished() block as well.
Step 5: Chaining Modbus Commands Together to Be Executed As a Non-Blocking Block
You can use processing methods to easily chain commands together in to a single execution block. The justFinished() method only returns when the block completes. If, in the processing method of the previous command, you start a new command, the internal state of the NonBlockingModbusMaster object changes to MB_START, in this state justFinished() returns false. justFinished() does not return true state is either MB_ERROR or MB_END. Sstarting a new command overwrites the current MB_ERROR or MB_END state with MB_START.
NOTE: An error in the one command does NOT automatically stop the rest of the commands in the chain from executing. You have the choice in the processing method's code whether to continue after an error and call the next command or to not call the next command if there is an error and so terminate the chain there. If you choose to continue processing the block after a command error, then you will most likely want to record somewhere else that an error has occurred. Successful retry()'s are not normally counted as errors.
The UNO_modbus_chaining.ino sketch illustrates this. There are two readHoldingRegister commands and the first one, after processing it results, call the second readHoldingRegister command. JustFinished() returns when the second command completes and its processing method has been called.
void processAddr_0(NonBlockingModbusMaster &mb) {
Serial.println(" in processAddr_0()");
// check for errors
if (err) {
retryCount++;
} else {
if (!err) {
Serial.println();
// else err continue or not?? can stop here by not calling readAddr_2()
readAddr_2(); // chain to read from addr 2 qty 2, this call will not fail as last cmd has finished
void processAddr_2(NonBlockingModbusMaster &mb) {
Serial.println(" in processAddr_2()");
// check for errors
if (err) {
retryCount++;
} else {
if (!err) {
Serial.println();
// finish here
bool readAddr_0() {
return nbModbusMaster.readHoldingRegisters(1, 0, 2, processAddr_0); // add processing fn
bool readAddr_2() {
return nbModbusMaster.readHoldingRegisters(1, 2, 2, processAddr_2); // add processing fn
void loop() {
Serial.println(" ++ start block reads ");
readAddr_0();
Serial.println(" -- Finished all reads.");
For convenience the readHoldingRegisters where put in their own methods but they could just as easily been called directly at the end of the processing method.
A sample output is:-
Conclusions
This tutorial describes the use of the NonBlockingModbusMaster library on an UNO using software serial. Use of the retry() method to recover from timeouts and and how to chain commands together into a single executable block was also covered.
