Introduction: How to Wash an Engine Bay
Video tutorial on how to wash dirt, grease, or grim away from your engine bay. Make sure your engine is cool when doing this procedure. This is the same procedure used by vehicle dealership and many detailers. Many people do not realize but your engine is always exposed to moisture or water, especially in the rain or snow. This can be applied to both gasoline and diesel engines.
Tools/Supplies Needed:
- soap (used in the video is Spray Nine)
- plastic bags
- water
- pressure washer or hose
- brush
- air compressor
- clean cloth
Step 1: Protection
First ensure that your engine is cool, this procedure should not be done with the engine running or warm. Have your vehicle parked in a shaded area which will reduce the chance of the soap drying. Using a plastic bag, cover up any high risk components such as the alternator, fuse panel, coil pack, and distributor.
Step 2: Degreaser
Using a degreasing soap, spray down the engine and allow the soap to soak for about five minutes, depending on how dirty the engine is.
Step 3: Washing
Using a pressure washer or hose, set it to the widest fan spray, be careful around the areas you have bagged off and any areas where your engine fluids are added. Continue to rinse the engine off, washing away any dirt and debris and thoroughly to remove any soap residue. Once finished, inspect for any dirt which may be remaining and if there is dirt remaining you can spray the engine again with the soap and use a brush if needed to agitate the built up dirt. Again rinse thoroughly.
Step 4: Removing Water Residue
Use compressed air to blow away any water residue which will help dry the engine and the assistance of a clean cloth. The will reduce the chance of water spots and remove any poling water which may cause problems.
Step 5: Remove Protection
Now remove the plastic bags. Underneath you may have dirt exposed, therefore use a damp toothbrush and cloth to remove the left over dirt so you'll be left with a clean surface.
Step 6: All Done
Leave the hood open, park the vehicle in the sun and allow it to dry and once done, your vehicle is ready to use. As a form of rust protection, you can apply a spray on rust proofing oil spray in areas such as within the hood cavity, inner fenders, radiator support, shock towers, etc.
