Introduction: How to Whiten Adidas Boost Soles
Want to clean up the dingy Boost sole on you Adidas shoes?
While the comfort and functionality of the Adidas Boost sole lasts much longer than the clean aesthetic, it can be refurbished to look new again with a little bit of elbow grease and skill.
-Scrub brush (with water or shoe cleaner of choice)
-Towel (scrap for drying/cleaning)
-Shoes that need to be cleaned
-White sharpie oil pen/marker
If needed:
-Painters tape
-Sharp knife (utility or exacto)
Links to supplies:
Sharpie Pen
https://www.walmart.com/ip/Sharpie-Oil-Based-Paint...
Scrub Brush
https://www.walmart.com/ip/Great-Value-Tile-Grout-...
If Needed:
Painters tape
https://www.walmart.com/ip/ScotchBlue-Original-Pai...
Exacto Knife
https://www.walmart.com/grocery/ip/X-Acto-No-1-Kni...
Step 1: Prep/Clean
To prepare the shoe, use water or cleaning agent to remove excess dirt and debris from shoe.
Step 2: Dry
Once the shoe is clean, use towel to dry shoe. You must ensure that the sole is completely dry and clean before Step #3.
Step 3: Trace the Edge
Using the Sharpie pen, carefully trace the edges of the sole (around the bottom rubber sole and as close as possible to the shoe's upper material). This can help keep you from mistakenly marking any parts of the shoe you do not want to whiten. If needed, use the painters tape to tape off the outside of the edges.
Step 4: Fill In
Once you’ve outlined the edge of the sole, continue to fill in the middle while being careful not to mark any other unintended areas of the shoe.
Step 5: Check
Allow the shoe to dry. Once completely dry, check for any areas that may have been missed and fill in as needed. Allow the shoe to dry again.
Step 6: Rock
Put shoes on and rock with confidence!
