Introduction: How to Wirelessly Control a NEMA 17 Stepper Motor With an ESP32 and an A4988 Driver Board
In this tutorial, you’ll learn how to control a NEMA 17 stepper motor with an ESP32 and an A4988 driver board.
What You Will Need With Link
  1. ESP32
  2. A4988 Driver Board
  3. NEMA 17 Stepper Motor
  4. Jumper Wires
  5. 12V Power Supply
For the power supply i use this adafruit HUSB238 USB Type C Power Delivery Dummy Breakout. But you can use any 12v power supply but it has to be less than 1.2 amps or it will break the A4988 driver board
Step 1: Installing Libraries
For this you will need 1 libraries the AccelStepper to download this go to Tools>Manage Libraries or you can press Ctrl+Shift+I once you open library manager type in AccelStepper and download the one by Mike McCauley
Step 2: Wiring Diagram
You can use a capacitor but it is not required
Step 3: Code
#include <WiFi.h>
#include <ESPAsyncWebServer.h>
#include <AccelStepper.h>
const char *ssid = "SSID-HERE";
const char *password = "PASSWORD-HERE";
AsyncWebServer server(80);
// Define stepper motor connections and steps per revolution
#define motorStep 14
#define motorDir 12
#define motorEnable 4
AccelStepper stepper(1, motorStep, motorDir);
void setup() {
  // Set up serial communication
  Serial.begin(115200);
  // Connect to Wi-Fi
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(1000);
    Serial.println("Connecting to WiFi...");
  Serial.println("Connected to WiFi");
  // Wait for connection
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: http://");
  Serial.println(WiFi.localIP());
  // Initialize stepper motor
  stepper.setMaxSpeed(1000.0);
  stepper.setAcceleration(500.0);
  // Define web server routes
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send(200, "text/html", "<html><body><h1>Stepper Motor Control</h1><p><a href=\"/forward500\">Forward 500</a></p><p><a href=\"/backward500\">Backward 500</a></p><p><a href=\"/backward2000\">Backward 2000</a></p><p><a href=\"/forward2000\">Forward 2000</a></p></body></html>");
  server.on("/forward500", HTTP_GET, [](AsyncWebServerRequest *request){
    stepper.move(500);
    stepper.runToPosition();
  server.on("/backward500", HTTP_GET, [](AsyncWebServerRequest *request){
    stepper.move(-500);
 server.on("/backward2000", HTTP_GET, [](AsyncWebServerRequest *request){
    stepper.move(-2000);
 server.on("/forward2000", HTTP_GET, [](AsyncWebServerRequest *request){
  // Start server
  server.begin();
void loop() {
  // Handle any necessary background tasks
  stepper.run();
Step 4: How the Code Works
Network Credentials
Insert your network credentials on the following variables.
Motor Speed
You can set the max speed and acceleration by changing the number in this line
Web Server
By defualt i added 4 modes but you can add as many ad you want
to change how far the motor moves change the stepper.move command
Step 5: Uploading the Code
After inserting your network credentials upload the code to your board.
If you have an ESP32 you should select ESP32 in the ToolsBoard menu.
After that, select the COM port in Tools Port.
Finally, upload the code.
After successfully uploading the code to the board, open the Serial Monitor at a baud rate of 115200. Press the RST button so that it restarts the board and it starts running the code.
You will see a link go to that link in your browser and you will be able to control the NEMA 17 with an ESP32.
