Introduction: How to Add Scripts to RSBot
Hello,
today i will be showing you how to add a script to RSBot.
This is very simple and will not take that long.
Step 1: 1) Gather Necessary Items
You will need the following things:
1) Java Development Kit - DL - https://cds.sun.com/is-bin/INTERSHOP.enfinity/WFS/CDS-CDS_Developer-Site/en_US/-/USD/ViewProductDetail-Start?ProductRef=jdk-6u23-oth-JPR@CDS-CDS_Developer
2)RSBot(DUH)
3)Scripts to add (Can be found at powerbot.org)
2)RSBot(DUH)
Step 2: 2)Saving the Code Properly
Usually when you get a script off of powerbot, it is a lot of Java code. To save this you will need to open notepad (or another editor) and paste ALL of the code. When you save it, save it as the name you are told to save it on the page you got the code with the file extension .java. Save it into the folder named Sources inside of the folder Scripts.
Step 3: 3) Compiling the Scripts
Now go back to the main RSBot folder and double click the Compile-Scripts.bat . If you get an error, either the source is messed up or you need to fix the .bat file. To fix the .bat file, right click it and select edit. Delete all of the code and paste this in there:
@ECHO OFF
TITLE RSBot Scripts
SET cc=javac
SET cflags=
SET scripts=Scripts\Sources
SET scriptspre=Scripts\Precompiled
SET jarpathfile=Settings\path.txt
IF NOT EXIST "%jarpathfile%" (
ECHO Path file does not exist. Please run RSBot and try again.
GOTO end
FOR /F "delims=" %%G IN (%jarpathfile%) DO SET jarpath=%%G
CALL FindJDK.bat
IF NOT EXIST %scripts%\*.java (
ECHO No .java script source files found.
GOTO end
ECHO Compiling scripts
ECHO. > "%scripts%\.class"
DEL /F /Q "%scripts%\*.class" > NUL
"%cc%" %cflags% -cp "%jarpath%" %scripts%\*.java
:end
PAUSE
EXIT
It should then work.
@ECHO OFF
TITLE RSBot Scripts
SET cc=javac
SET cflags=
GOTO end
CALL FindJDK.bat
GOTO end
:end
PAUSE
EXIT
Step 4: 4)Have Fun!!
Enjoy all of your new scripts!! If you liked this instructable, please download this file !!
http://sharecash.org/download.php?file=1684433
Thanks!!
Thanks!!
