Introduction: How to Amplify the Sound of Your Phone 3 Ways
Hello every one today i will be telling you the three ways to amplify the sound of your smart phone absolutely for free. Enjoy!
Step 1: First Way
You will need :
1. One empty toilet roll
2. Two empty plastic cups
3. A phone
Step 2:
First cut a whole on each cup that matches the size of the toilet roll.
Step 3:
Then cut a line on the toilet roll that is the size of the bottom part of the (where the speakers are).
Step 4:
After that hot glue all the things together and you're all set to place the phone in the slit and place the structure side ways so the cups open side is facing you.
Step 5: Second Way AKA. the Easiest Way
You will need :
1. A bowl
2. A phone
Step 6: The Only Step
Just place the phone in the bowl and listen to the sweet tunes!
Step 7: Third Way AKA the Wood Way
You will need :
1. Some wood
2. A phone
Step 8:
First cut out two pieces of wood that are 8 cm by 8cm.
Step 9:
Then measure the width of the bottom part of your phone (where the speakers are) and then cut out two sticks the width of the bottom of your phone and the height of the two wood pieces you cut out.
Step 10:
After that take the two wood sticks and the two wood pieces and place the stick between the two pieces and nail it together or put it together with glue and seal the structure from beneath with wood or anything.
Step 11:
Then take a plastic funnel any size and drill a whole in that wood structure and glue the funnel in that structure and you're all set to go.
Step 12:
Now place the phone in the slit and listen to some loud music.
BYE and thanks for watching.
