How to Bind a (real) Small Book
Intro: How to Bind a (real) Small Book
Hello, in this instructable I will show you how to bind your own small notebook.
I know, there are tons of book binding tutorials on the internet which are often really good, but almost none of them are how real books are made.
In this instructable I will use the same method as book binders do. (But with crappy materials and almost no tools)
It is just way more work and the result will (read should) look just the same but I swear it will be strong and very durable. (Seriously, I messed up at a certain point and just tearing the covers off was quite a challenge)
Why a small book? Well, to make a large book one requires a large industrial cutting machine to cut the large stack of paper with a clean cut. It just doesn't look good without that.
And the result fits in a pocket. Have you ever noticed that pocket-sized notebooks don't really fit in a pocket? Well this one has a hard cover and it fits in a pocket so good that I didn't even notice it was there and thought I had lost it.
Well, this is what you will need:
-Sheets of paper (the thinner the better, printer paper will do)
-A sheet of nice paper (you know, when you open a book there is always an empty page)
-Something to cover your book in.
-pressed cardboard ~1mm thick (covers)
-thin cardboard (back)
-some kraft paper (the brown paper you send things in )
-Needle (to sew the sections together)
-sewing wire
-some small flat fabric ribbon (to sew the sections on)
-some fine gauze or mesh (to put on the back of the sewn sections)
-good glue; bookbinders glue
-bad glue
-cutter
-cutting machine (if you have one, but I don't think it it is really necessary)
-sand paper
-sewing bank (see step 4 last picture)
handy:
some clamps
flat boards
weights
-sewing wire
-bad glue
-cutter
-sand paper
handy:
some clamps
flat boards
weights
STEP 1: The Paper
I will make a book of A8 size.
The size doesn't really matter but A8 is just a normal A4 sheet fold in half 4 times.
Cut your A4 sheets in 8 A7 sheets and fold each A7 sheet in half.
These will make the main body of the book.
To make the sections, put 3 of these folded sheets in each other, later these sections will be sewn together.
Do exactly the same with the nice paper, you need to make only 2 of them.
These will be the cover sheets.
The explanation is also visible in the pictures.
STEP 2: The Ears
Now, cut two pieces of paper of the same height (7.3 mm in my case) of the sheets of paper you just made BUT a littlebit less wide. (Mine are about 60% smaller than the other ones)
Fold them NOT in the middle but a little bit more to one side so that there is a large part and a small part.
Look at the picture.
The size doesn't matter but make sure it is big enough (look at step 5 to see what they are used for so you can get a better estimate of how big they should be)
The paper doesn't matter but it shoud be a littlebit stronger than normal paper, I just used the left over of the nice paper.
STEP 3: The Ribbons and the Holes
Now, the 10 sections will be sewn onto some ribbons. Since this is a small book, I will only use 2 of them. For normal books 3 are used.
Now clamp the sections between 2 boards (I used very strong cardboard). Draw with a pencil and a ruler a line at about 0.5 to 1 cm from the edges depending on the size of your book. (I did 8 mm) Locate the middle and place your ribbons about halfway between the middle and the first line you drew.
Draw a line just next to the ribbon you're holding. You will later sew the ribbon into place at that location.
It doesn't matter very much where you place your ribbons. If it looks good, it probably is.
Normally for normal books there are quite precise places where to put your ribbons but I don't remember them and lost the piece of paper where they are on. But for a book this small it doesn't even apply.
Try to make it symmetrical! Because later while sewing I flipped some of the sections and they are a tiny bit out of place, but this doesn't matter.
Now get a knife and gently cut along the 6 markings you have applied. The ones at the side and the ones next to your ribbons. Make the cuts deep enough to penetrate all 3 sheets of paper.
This will create the holes trough which you will guide the string whilst sewing.
get the sections out of the clamp.
STEP 4: Sewing
Get the sections out of the clamps.
Place one section on the sewing bank and attach the two ribbons to the bank so that they are located between the cuts you have made. (so they are located where you want to sew them on.)
So, get a needle and poke trough the holes of the section you have already made. This is to make them bigger so the sewing is easyer and if your knife didn't go all the way trough, you can complete the holes.
Use the annotations in the pictures for a more clear explanation!
Also, update: I have added 3 diagrams.
Now, place your first section onto the sewing bank and sew. (go in and out the holes with your wire).
When you reach the end, place another section and do the same.
Then the third section, when you finish that one, go under the connection between the previous sections.
Go on and on till all sections are finished and secure your string (I used a triple half hitch )
Always pull the string to tighten everything up when you reach the end of a section!
Then, get everything out, and trim the excess of string and ribbons.
STEP 5:
Now you have all your sections together, the cover sheets and the ears must be added
So, fold the sheet so that it is closed and apply some glue in a thin area 2-4 mm from the fold. It's easy to use an other sheet of paper to cover most of the nice sheet up and leave a small stroke open at the fold.
Then press the sheet onto your book so that it is as if you just added 2 extra pages. (one of them will be the empty page, the other will be glued to the cover)
Add the other sheet to the other side.
Then, gather the ears you have made and apply glue on the biggest flap but do not completely cover it with glue. There must be a stroke without glue . Later you will have to rip some of it off so you will need a hold-on (see later).
Apply both ears onto the nice sheets you have just glued on.
The last pictures shows the result you should have now.
STEP 6:
Now the gluing starts (and I really hate glue)
Now, put everything between the clamps and let the uppermost bit out . Apply lots of glue and let it dry a bit.
Now adjust the book in your clamps so that the ears are just free.
Then get some fine gauze, I used some from an ornamental ribbon and cut some piece about 1.5-2 cm smaller than your book.
It was something metallish that is NOT GOOD, rather find some piece of fabric. (or maybe the real book binders gauze but that may be too thick) So I t didn't glue very well on the back of the book and I had to use other glues and became a dirty mess. But it is still good but doesn't look nice.
Then find some small piece of Kraft paper a little bit smaller than the height of your book and a little wider than your piece of gauze.
Apply glue on it and stick the piece of kraft paper on the gauze.
Put the entire book between the clamps or place it under a press to let it dry.
When the glue is dry, get the book out of the clamps and try to rip of the inner flap of the ear. You will notice that you can only rip of the part you didn't glue on. That is good!
The "ripping off" makes sure that there is a slow decrease in thickness of the paper so that you won't see the ear trough the paper when your book is finished.
Make it smoother with some sand paper.
STEP 7: Cutting of the Sides.
This step normally requires a big cutting machine that can cut thick heaps of paper.
If you can use one like this, DO IT!
The point of this is to cut a very small sliver of each side of the pages so that the heap of paper gets a book-like appearance.
I instead use a normal (max 12 sheets of paper) and had to unscrew some things in order to fit the book inside it.
This was NOT good, read further to see maybe a better approach which I will try next time.
So yes, basicly try to cut a small sliver of each side of the book (NOT THE BACK) to get a nice smooth surface. This kind of works with my cutting machine but somehow the cut always gets skewed
(See the pictures)
In order to get rid of the skew edge of the book I clamp everything between the clamps and started sanding. This works
surprisingly well. Next time I will try to sand the edges with a sanding machine instead of trying to cut them.
There are indeed lots of brims at the edges but they are easily removable.
You can also notice that the outermost pages have bent over edges from the sanding, but placing it between the clamps again for a few minutes fixes that.
(See the pictures)
STEP 8: The Covers
Now measure up your your book.
Cut out rectangles out of fairly thin pressed cardboard (mine 1mm thick) .
The rectangles should have a size [HEIGHT OF BOOK + 4MM] x [WIDTH OF BOOK - 2 MM]
Give a few strokes with sand paper on the edges to make them less sharp. (NOT TOO MUCH!)
Place both boards on the side of your book so that they get over the side of your book by an equal amount at all sides (except the back of course) and draw a line to know where they should come
Now apply glue to the outer flap of the ear and just as the big one on the inside keep away from the edge (the one away from the back)
Place the cover at the line you just made but watch out for parallax, I misplaced my cardboard almost 1 mm from the edge and you can clearly see that it is not good in the final result.
Finally rip of the extra unglued piece of flap of the ears to again get a nice transition between paper and no paper.
STEP 9: The Headband
Well, normally I continued without this step (because I forgot) but then I messed up and had to restart from step 8 so you will see both green and red cover wrapping. The green one failed because it was too thick.
The headband is the piece of fabric you pull on when you pull a book out of a shelf. Often it is a bright colour.
The normal stuff is just too thick to use in this small book so I will make some myself.
Usually you can't do wrong by using the stuff you are wrapping your book in but you can choose anything you want.
So, cut 2 small pieces of your cover wrapping to make the headband.
Use a small piece of string (I used the a left over from the sewing) and place it in the middle of your piece of wrapping.
Add glue and fold it in half with the string in the fold so that it bulges a bit.
Apply force so that the bulge is larger at one side than the other.
STEP 10: The Back
As you can see I continue with the first try in which I forgot to add the headband
Find a piece of thin cardboard. I used a piece of a "granny" box or a cereal box will be the same.
But try to find something stronger than that but not much thicker!
Cut the piece of cardboard to a rectangle with the same hight of your pieces of cardboard and with a width equal to the with of your book with the covers. Try to do that width as exact as possible.
This will be the back of your book cover
Then, find some kraft paper and cut out a piece with hight smaller than your book and width a lot more than the width of your back.
Apply glue on the kraft-paper and put your card board back onto it, then stick all of it onto the book. As you can see, the back is not glued directly to the book.
STEP 11: The Cover Wrapping
This is the step that makes or breaks your book. (usually break with me)
And I am absolutely terrible in it. In large books it is fairly doable but in small books it is quite hard. Look at the pictures the dirt is caused by semi-dried-up glue from retrying and retrying.
Since your book is small, use thin cover wrapping (so not thick leather or something like that) I used something I thought was thin but it was not and I screwed up.
Secondly, use BAD GLUE glue that dries very slow and doesn't stick very hard so that you can redo things several times. I made my bookbinders glue bad by adding a lot of water (but it still dried too fast) maybe use some "pritt stick" or something like that.
With my watery glue, cardboard back and covers got a bit wet and they deformed a bit sadly enough.
So, first of all, cut at both sides of your book, at both top and bottom a small slit in the paper between your cardboard back and the cover. It's easy with some scissors
Then, cut some piece of your cover wrapping about the size of your book and a littlebit more (about the size of your slits more).
Apply the bad glue on the entire piece of wrapping and the outside of your book and wrap it around the covers of your book. Use 2 toothpicks to press the wrapping inside.
Then, cut the corners of your sheet of wrapping but beware! Don't cut of too much because it will look really bad! Instead use a piece of cardboard of the same thickness as your covers and mark a line with that piece of cardboard one thickness away from the corner of your cover. Then cut off the corners.
Press down the covers and pull up the papers of your book to spread open the slits you have made, fold the wrapping on the the edge of your cardboard back into the slits. this is quite strange and difficult. But look at the pictures.
Use a pencil or a stick to press it in as deep as you can.
Do the same for both top and bottom.
Watch out that you don't peel of your headbands!
Fold over the entire top and bottom wrapping
Then fold over the piece of wrapping at the ends of your cover but watch out at the ends! It is easier to first press up on the wrapping at the corner and then gently pull the rest of the wrapping over it.
I know this is explained a bit strange but it is quite intuitive when you do it. The point is that it has to look nice (sort of nice in my case).
Then press the toothpicks in the joints between the covers and the back and put it in a press or in my case stack a lot of weight on it.
Also place some papers between the covers and the rest of your book first so that the pages aren't glued to the covers.
STEP 12: Final Touches
Now, I don't have many pictures of this but you need your cover paper glued onto the your cover.
First of all trim the excess wrapping that you have fold over your cover by giving it a cut and peeling it off. Make it so that when you fold over the cover paper, it just gets over your wrapping and you don't see any naked cardboard.
Then, apply some glue to the cover and fold over your cover paper.
Do the same with the other side.
Put some paper between the cover papers and apply some weight again.
STEP 13: Result
The result is a small book.
I am not quite happy with the result, things got a bit messy.
Also, the cutting technique from Step 7 should be better, even with the sanding the block of paper was a bit skew so, adding the straight covers resulted in skew looking covers.
I will redo this book another time in the coming months.
So, what do you think of my first instructable?
All suggestions are welcome.
36 Comments
JoeG9 8 years ago
This is a wonderful Instructable. I just made one book in the past 3 days and I have another in the process. Its really amazing to see how books are really made and be able to do it yourself. I'm also amazed how common and around-the-house the materials can be. Thanks, i could never have done it without this demo!
Sparticles 8 years ago
Thanks!
I'm glad you like it!
Actually at the moment I'm working on a bigger, more practical book for a new instructable that will be more detailed and with better pictures. The book is almost finished, but the instructable will take some time.
Luigi Pizzolito 9 years ago
Cool!
Best and most detailed ible iv'e seen yet
Jonny1128 9 years ago
thehbird 10 years ago
Sparticles 10 years ago
And if you want another colour along the spine, you can do it in exactly the same way. But with a smaller piece only for the spine (and a small part of the covers). And then you can add cloth with an other colour for the rest of the covers. But you must look out for difference in thickness of the materials.
sokamiwohali 10 years ago
but nonetheless great job on your first ible!!!
And yes, my instructable uses a different technique. It is the technique I learned some time ago.
I have been wanting to redo this instructable for a larger book in a more serious and clear way with better photos. (Larger books are way less clumsy/messy) But I just don't get to it.
Arrioche 10 years ago
vincent7520 10 years ago
Je vote !!!… Je vote !…
J'ai tout bien compris à part le moment avec le papier de verre à la phase 6 (step 6).
Bravo.
A quand un livre avec un mouvement à la Anomalocaris ? ;D
Moi-même j'ai plein de livres dont la reliure est cassée et ton job est une bonne source. L'ennui c'est que ce sont des livres brochés dont la colle a séché. Chaque page est indépendante et je n'ai pas vraiment envie de faire des feuillets, ce que font les relieurs traditionnels. Nettoyer la colle sèche et réenduire de colle appropriée ne marche pas. Je cherche (faiblement) un moyen. Si je le trouve je le publierais ici. En attendant si tu as une idée…
Encore felicitations !…
Le papier de verre est utilisé pour 'aplanir' les côtés du livre.
Normalement on utillise une grande machine à couper pour coupér une petite tranche des côtés. Mais je n'avais pas accès à une machine comme ça.
Donc j'ai essayé à utiliser papier de verre et ça marchait bon.
Je crois qu' enlever la colle (avec un petit couteau) et réenduire est la meilleure solution. (avec une grande machine à couper c'est facile et vite mais vous perdez un peu de papier)
Bonne chance!
instructageek 11 years ago
Sparticles 11 years ago
dj. navarro 11 years ago
Bill WW 11 years ago
Bill
EtCetera112 11 years ago
