Introduction: How to Build Halo Armor
Hey guys, this is my entry for three contests! Halloween, Office Supplies, and Gorilla Glue! I'll be showing you how to make Halo armor! I really need to add more to this intro.. what should I add?
PS. Vote for me!!! :D
Step 1: Materials
Cover/card stock
Scissors
Butter knife
Exacto knife / box cutter
Cutting board
Glue (If you like, use gorilla glue. It is stronger, but in the long run it won't make any difference after fiberglassing, but any glue would work. The reason I have chosen this one is just to save money)
Time
Computer
Printer
Pepakura Viewer
A helmet file to be used with pepakura:
MK VI by FLYINGSQUIRL
RECON by Kirrou
ODST by BELAKOR
In my opinion, the MK VI is the most difficult, but it is the most popular. If you want simpler models, then just post a comment and I'll give you a link to one!
Scissors
Butter knife
Cutting board
Time
Computer
Printer
Pepakura Viewer
RECON by Kirrou
ODST by BELAKOR
Step 2: Scaling
If you are making a helmet, skip this step.
If you are building body armor, you have to do this step, unless you are 7 feet tall.
To start, go to the link for pepakura, but download the designer version instead.
1) Open up your armor file in it.
2) Click "2D Menu" -> "Change Scale" -> "Scale Factor"
3) Now depending on your hight, you will have to scale the armor differently. I will only cover the MK IV armor because each has a different ratio to your body hight and there are way too many pieces to cover. First find your hight in millimeters. You can do this by finding your hight in inches, (not feet), and then multiplying it by 25.4. Use this picture as reference. Measure how big the the guy is in the picture, then how big the armor is in comparison. Once you have that ratio, apply it to your own hight. Enter that into the hight option in the scaling menu, and the rest will automatically change according to the scale. Also make sure to measure from the highest and lowest points. You will have to measure the shoe according to your own shoe size. Just measure the length of your show, then enter that into the scaling menu.
Step 4) Now some pieces on the right side may be crossing over the lines and that's not good, because then they will print half on one page and half on another. Just move them around until they all fit inside of pages, then all you have to do is print.
| Armor Piece | Download Link |
| Chest | Linky :) |
| Bicep | Linky :) |
| Forearm | Linky :) |
| Hand-plates | Linky :) |
| COD plate | Linky :) |
| Thigh | Linky :) |
| Shin | Linky :) |
Step 3: Pepping
The first step in building Halo armor is called pepping, which is just completing the paper stage of the build. If you have done step 1 (which you have to do if you are doing any piece other than a helmet), then skip to "3)"
1) Open your file in Pepakura Viewer.
2) Print it out onto your cardstock.
3) Crease every single dotted line with your butter knife, This is a long and tedious process, but if you don't do it then your pieces will be extremely hard to fold, and will not look nearly as crisp or sharp.
4) Cut out your pieces, if you are not comfortable using an exacto knife, then use scissors. This is also a long process, but do not give up it is worth it in the end :)
5) Start gluing your pieces together. The numbers on the pieces represent which pieces they go together with. For example, 213 will be glued with 213.
6) You are going to have to do this with every single piece, It will be boring, but as always, definitely worth it!
Step 4: Resining
BEFORE STARTING: Fiberglass resin is very toxic, you should only do this in a well ventilated area such as outside, or with a respirator. Also make sure to use disposable gloves. You WILL NOT be able to avoid getting some of this onto your hands. This stuff is very hard to get off, and I regret not wearing gloves 2 showers later :P Fiberglassing is the next step, for all those who are wondering. Also, make sure to only do this step on the outside.
Some things you will need: I forgot to add the paintbrush, sorry :(
1) The piece you will be fiberglassing
2) A fiberglass repair kit I bought for about $25 Canadian. If you can find it, it includes numbers 3-6
3) Fiberglass resin ($15)
4) Fiberglass resin hardener ($5)
5) Fiberglass mat ($5) (Not needed for this step)
6) Squeegee-like thing for spreading body filler ($3) (Not needed for this step)
7) Plastic cup and something to mix with
Steps:
8) Open your can of resin (That was hard wasn't it? XD)
9) Pour some into your cup. The amount in the picture was enough for my entire helmet (the outside). After that, put the lid back on. You don't want all those fumes in the air do you?
10) Pour a few drops of hardener into the resin. I used 5 drops for the amount of resin I used.
11) Mix
12) Dip your paintbrush in and "paint" the mixture onto your helmet. Make sure to do a light coat, or else it will warp.
13) Just a picture of my progress while working
14) A resined helmet!
Now leave your helmet somewhere to dry, make sure it doesn't touch anything though. What I did was I put my bike on it's side, and put my helmet over the handle.
Steps:
11) Mix
Step 5: Fiber-Glassing
Now you have to fiberglass the INSIDE. Make sure to take all the same precautions as resining. Also make sure that the resin from the previous step is completely dry before starting this.
1) Gloves
2) Fiberglass resin
3) Fiberglass matt
4) A resined helmet
5) Something to work on
Steps:
6) Get out you fiberglass matt
7) Cut it into a bunch of small strips like how I have it. Also make sure to make a pile of really small pieces, for those tight areas
8) Pour some resin into your cup. You are going to need a lot more than how much you did for the previous step
9) Put in some hardener. Use you judgement to determine how many drops you need
10) Stir it up
11) Apply some resin to a small area, just slightly larger than one piece
12) Put your piece down on top of the resin
13) Now put some more resin on top of the piece of fiberglass matt, so that it will change colors and it may even become see-through. Try to dab the brush rather than paint the resin on. If you try painting it on then some of the fibers will stick to the brush and you will get a big sloppy mess.
14) Keep going until you have done the entire inside of the helmet. Some areas will be trickier than others
15) Yay you're done! Now just leave it to dry. When it's dry, you will be very surprised at how strong and hard it is!
1) Gloves
2) Fiberglass resin
3) Fiberglass matt
4) A resined helmet
Steps:
10) Stir it up
