How to Build a Safe and Strong Baby Gate
Intro: How to Build a Safe and Strong Baby Gate
Since I had built my Toddler Bed Guard out of PVC, I chose to do something similar for a baby gate. This would also apply nicely to someone who needs a pet gate.
This particular model is pretty simple and uses just PVC components to work. There are two ‘Slip Tees’ in the structure that allow the gate to slide vertically, just slightly so that you can lift it up and over the ‘Table Caps’ that it will snap into. Once over the Table Caps, just press down and it is as secure as can be.
Now, before you child-safety advocates turn on me, here are a few notes about this design:
- It’s made from furniture grade PVC and fittings, obtained from formufit.com, which is non-toxic, contains no dioxins (the nasty stuff they make plumbing PVC with), and is impact and UV-degrade proof (it won’t break down in sunlight).
- The slats are all 2-3/4” apart, which is BELOW the required 3” of distance between slates.
- It is extremely strong. I can put my entire weight on it (215 lb. male) closed and it will not budge.
- All corners and edges are rounded, so no snagging.
- There are no pinching mechanisms in the gate once closed.
- Finally, this is MY choice to make this for me and my family. If you detest such a project, dont make it.
I plan on augmenting this Instructable to make a baby-corral out of the same thing, but making legs that jut out from each side for stability. Look for that one soon.
STEP 1: What You Need.
As I mentioned in the introduction, I used furniture grade PVC and fittings. First its safe (non-toxic) as it’s made from the same type of PVC used in kids toys, and second, it just looks much better. I built the prototype out of plumbing grade PVC and it looked ghastly. Bonus also is that furniture grade PVC parts have a few more ‘clever’ components to make it easier, such as the Slip Tees and Table Caps.
I ordered all my parts from Formufit (www.formufit.com) as they are the least expensive and have the best selection of parts.
Here are the parts I ordered:
- 12 x 1-1/4” PVC Tees
- 2 x 1-1/4” PVC 90 Degree Elbows
- 2 x 1-1/4” PVC Slip Tees
- 2 x 1-1/4” PVC Fitting Caster Inserts
- 4 x 1-1/4” Table Caps
- 2 x 1-1/4” Internal Domed End Caps
- 3 x 1-1/4” 5’ Furniture Grade PVC Pipe
I also had some spare 1-1/4” Plumbing Grade Pipe to make the connecting inserts, which are not exposed. Fairly inexpensive, a 10’ section will run you $3.00 at Home Depot or Lowes. They will cut it down for you if you need.
Hardware
You will need the following hardware to secure everything together:
- 2 x 1/4” x 2.5” or 3” long Hitch Pins (Ace Hardware)
- 1 bag 3/4” Wood Screws (Full Thread)
- 1 can of PVC Cement
Normally I would have used a Miter Saw to make all of the cuts, but I chose to use a hacksaw, as it was just as fast (a little de-burring was needed). I did need a ¼” drill bit to make holes for the ‘hitch pins’. Everything else is screwing, so just a power drill a couple of drill bits and a
- Phillips bit should get you through this.
- Power Drill or Power Screwdriver
- Philips Head Bit
- Hacksaw
- Measuring Tape
- 3/22” drill bit
- 1/4” drill bit
- Countersink Bit
- Knife or Deburring Tool
STEP 2: Design
In order to accommodate for larger doors, you will need to add another ‘T-Section’ (or more than one) for an additional 5 inches in width. An example is shown below in one of the SketchUp diagrams.
To accommodate for doors between 33” and 37” you can increase the parts that connect to the wall by an inch on each side, but do not go over 2” or you will make the span between the frame and the doorway more than a 3” gap, which is not recommended under ‘baby gate standards’.
I’ve made the Google SketchUp plans for the baby gate available here on the Google SketchUp 3D warehouse. Feel free to modify/customize them as you need.
STEP 3: Cutting
One benefit of miter saw cuts over a hacksaw: deburring. You will need to debur each of the PVC segments using a pocket knife, razor blade, or if you have one, a deburring tool.
I’ve provided a cutting template for all of the lengths of furniture grade and plumbing grade PVC pipe below. I’ve tried to maximize usage, and it has worked out pretty good for me. Make each cut, as straight as possible for each piece
You’ll need a total of each of the following for the Furniture Grade PVC pipe:
- 5 x 30”
- 1 x 20”
- 4 x 2.5”
You’ll need a total of each of the following for the Plumbing Grade PVC pipe:
- 12 x 3"
Once the cuts are made, throw the parts into a box so they don’t roll away on you.
STEP 4: Table Cap Modification
It’s a little difficult to explain the cut, and I will let the diagrams below do most of the work, but basically you make one horizontal cut right above where the top of the tab meets the cap and one vertical cut with a hacksaw along two of the supports of the Table Cap. This will remove a small crescent shaped section that you can throw out. You could also perform this with a Dremel tool, if you are so inclined.
TIP: When cutting the table cap, secure it with screws to a table or piece of lumber, to make it easier.
Once your cuts are made, sand down all sharp edges with sandpaper or a sanding block, to make the edges smooth. We don’t want any spikey edges!
STEP 5: Assemble the Top
I like to use a countersink bit attached to the drill so that it makes a nice indentation for the screw head to go into. It keeps in clean and won’t allow snagging of clothing or little fingers.
I do use PVC cement for a couple of items later.
Should you choose to use PVC Cement, remember: PVC CEMENT ESSENTIALLY MELTS THE PVC TO MERGE THE PIPE AND FITTING TOGETHER, IN ABOUT 30 SECONDS, SO MAKE SURE THAT THE PARTS ARE LINED UP AND GOING IN THE RIGHT DIRECTION WHEN CONNECTING THEM.
We’ll start assembling the top of the gate. For this you will need two (2) 90 degree fittings, five (5) tees and 6 (six) pieces of the 3” plumbing grade PVC segments.
Simply assemble the fittings as shown in the diagram below, with a 90 elbow first, followed by the four tees using a 3” Plumbing Grade PVC segment between each fitting, then another 90 elbow. You’ll put another tee facing outward off of the final 90 degree fitting.
STEP 6: Assemble the Bottom
Assemble the fittings as shown in the diagram below, with a tee vertically positioned, and followed by four (4) tees facing upward, with another tee vertically positioned. Use the 3” plumbing grade PVC segments to connect them all together. Attach another tee vertically positioned facing outward to the top of the final tee.
STEP 7: Insert Pipe Into the Bottom
Insert the five (5) 30” segments of furniture grade PVC into the bottom section of the gate that we just assembled. Secure the pipes in place with screws. Insert the one (1) 20” segment of furniture grade PVC pipe into vertical tee that is off to one side.
Slip the two slip tees over the 30” segment of PVC pipe at the far end. This will be our hinge mechanism. We’ll get back to these later.
STEP 8: Attach the Bottom to the Top
Line up the top of the gate with the pipes already attached to the bottom of the gate and make sure they are all in place by pressing down hard on them. Then attach with screws to secure the whole deal.
STEP 9: Make the Gate Removable
Screw the table cap into a table or piece of lumber to secure it. Push the 2.5” furniture grade pipe segment into the table cap. It should be ‘slightly’ loose. Next, drill through the Table Cap and furniture grade pipe around 1/2” from the end of the table cap, through both sides.
Push in the hitch pin (it should be slightly difficult at first, as you have to get by the ball). It should go all the way through. You will see in my picture I used a 3.5” length hitch pin. I suggest a 2.5” or 3” at most.
Using the 3/4” screws on the outside of the Slip Tees (that are on the 30” pipe segment), secure the 2.5” segment of pipe to the Slip Tee. Do this for both Slip Tees.
STEP 10: Add the Catch Mechanism
STEP 11: Installation
Slip in the two Caster Fitting Inserts into the two tees on the bottom of the gate. These will act as feet. I recommend for hardwood floors to add a couple of felt pads available at most stores to make it easier on your floors.
Line up the Slip Tee/Table Cap combos with the wall or inside of the door that you want to install onto. Line up the Slip Tees with the with the Tees on the opposite side of the gate so that the whole thing looks symmetrical. This also allows free travel of the slip tees, which is part of the catch mechanism. Attach Table Caps to the doorframe, studs or wood structure with 2” wood screws.
Once attached, the gate should swing freely. Insert the two ‘modified’ Table Caps onto the ‘catch posts’ and line them up on the opposite wall or door frame. Make sure that the section that you cut out of the Table Caps faces UP. This is critical. You want them positioned so that the gate will snap into them. Screw these into the studs or door frame with 2” screws.
Enjoy!
57 Comments
tbcross 13 years ago
JeanineC 4 years ago
and print it out due to my "tricky" Chromebook. Is there anyone here who can email me the directions. I tried copying and pasting it to my email but that too is not possible. Is there a way to get a print out mailed to me ? Any help would be appreciated.
Thank you,
jcousi52345@dcc.edu
“Martha speaks” 3 months ago
AndrewDouglasBird 7 years ago
I highly suggest getting one of these for cutting instead of a hacksaw. Very quick and no burrs to clean up, or shavings on the floor!
my question, I went to the link for the “Google SketchUp” and it was not there; I live fulltime in an rv and one of my girls 🐾 will take any chance to escape and the other is a bully and will nip, so I needed something that I can put up to keep them both away from the door when needed && maybe an extra “gate” to put behind the entry steps so they can’t escape from under the steps, I have a 4’ fence around the rest of the area, but it’s the behind the steps that I need to secure. I was hoping with the “Google SketchUp” I could make sure I got enough supplies all at once. Since rvs are basically put together with smushed cardboard, I’m not too sure how I will attach the gate inside because nothing is “square” or even close to right angles ! ? !
juanentinta 1 year ago
nursetobe2 3 years ago
JohnM584 7 years ago
Here's the link for the fittings I used.
http://www.pvcfittingsonline.com/1-1-4-table-cap-f...
Pipe was purchased from Home Depot. 10' section of 1.25" was $4.95
Thx for sharing!
I built one and Thank you for posting the instructable. Made some MAJOR changes and saved a lot of money. Mine isn't to keep children out it's to keep my dogs out of the cats room. So the distance between uprights went from 3" to 5.5". Also there are only 4 uprights including the end ones. And since no kids are involved I was able to substitute furniture grade fittings and pipe for standard pipe. The whole gate cost me $30. You posting saved me a bunch of money, effort and headaches. Thx dude!
MisterHighway 7 years ago
Very well made build! I liked the idea and noted the Formufit website for my reference for future projects. However I started to do a cost estimate for this build using the parts subscribed but found it to be as expensive or more expensive than a regular sturdy baby gate. The pieces off of Formufit were $67.18 with $21.99 shipping alone. Those along with the other materials (hitch pins - 2@$4, pipe $3, glue $3) it'd cost approximately $103 to make. The Formufit must have gone up in price as at the time of build in 2010 you said was $48 per gate. You had a few supplies on hand but the cost of the fittings must have been much lower then. This has got my noodle going though with the design of the lock mechanism and the overall design. I wonder if there might be a way to incorporate some dowel or wood slats into that design with either bare (clean) wood or sanded and covered with a kid safe finish. It might lessen the need several of the fittings. Hmm. Interesting. But great job and thanks for sharing!
mmmisso 7 years ago
Awesome idea, I didn't know about Formufit. I have 2 mastiffs & knocked down or destroyed a number of wooden baby gates. We want them be able to come out on the deck w/ us, but until now we haven't been able to trust any baby gates against a 'charge' to get a cat or other animal. Since it's at the head of the stairs having the opening reduced by a standard baby gate is inconvenient. Looking at this I cane up with an idea that will allow the gate to swing back against the railing when not in use so the opening is totally clear. Once again, great idea & excellent 'able
GardenGranny 7 years ago
Great idea. I'm passing this on to my daughter whose Yellow Lab has outsmarted (or broken) several store-bought "baby" gates. Along with the instructions everywhere on Pinterest on how to paint PVC to look like wood, this not only looks like it'd work for said Lab, but would look less industrial in their home! Thanks for sharing!
kbbaktha 7 years ago
This one is a great simple design and doable by anyone with little common sense and very little tools.
I loved your comment No.6 about child-safety advocates.
beliakrousex 8 years ago
hahaha PCV. Make it wooden. Google 'WOODPRIX' :)
pattiemelt 7 years ago
Sorry, but I wouldn't recommend Woodprix to my worst enemy. In addition to stealing everybody else's ideas & plans, they promise you free plans, then don't deliver. And they spam you to death once they get your email.
http://www.thegeekpub.com/4358/woodprix-is-a-scam/
Trondwell13 7 years ago
Why PVC? Chlorine - not a contributor to greenhouse gases by any chance?
sl0j0n 7 years ago
Hello, all.
1ST:
I know this is old & all that, but some facts never change.
2ND:
The PVC used may not contain 'dioxins', *BUT*, does it contain 'plasticizers'?
Those compounds are carcinogenic, hazardous, poisonous, and toxic.
[AFAIK, *ALL* "plastics" contain 'plasticizers', added at the time of manufacture.]
The plastics companies have always claimed that their ingredients & processes are proprietary, so they wouldn't have to reveal what poisons are in their products.
"Plastics" are a nightmare of industrial pollution, and the source of many so-called "endocrine disruptors".
PLEASE, be *VERY* careful exposing children to them.
Have a GREAT day, Neighbors!
Artur Zawadzki 7 years ago
Fajny pomysł, bardzo mi się podoba!
