How to Build a Cajon
218,617
281
31
Introduction: How to Build a Cajon
About: Hi! I'm a guy who find it's cool to create things!
A Cajon is a common instrument in South America. It is often related to flamenco music/ samba.But you can use it just as a real drum with a guitar for accompany. When you play the cajon, you are sitting on it an drumming with your hands on the front side of the drum. You can find out a whole technics and learning stuff if you just search on cajon drumming on youtube for example.
In this instructable I will tell you how I builded my Cajon!
Step 1: The Construction
I looked up a whole bunch of sites on how to build cajons on google. There were plenty of people who had nice instructions on how they builded there cajons. But i decided to create one from a construction i found on Orcana Artesania* . It was an easy instruction except it was in Spanish but I did only use the measurements. Instead of having guitar strings in it I bought a snare drum wire that i put in it.
*Link : http://www.ocanartesania.com/
This is the parts of the box and the measurements: (see the PDF file)
Step 2: Building the Drum
The building of the drum box was quite easy. I used plywood as material. For the frontside I used a thinner type of plywood like 3 mm thick. Then i cutted out the parts. I used a circle saw. For the hole I first drilled a small hole then I used a jigsaw to cut out the larger hole. When I had all the parts I used screws/nails and glue to put all the parts together except the front side. The front side i used smaller screws and no glue. The thing is that if you use screws it is useful for tension of the drum surface. Before I screw the frontside I fixed the snare drum wire inside it. It was the trickiest part. I had an idea that I stole from another building site I found. I had two thin iron boards that held the plastic tape of the snare wire. Then i had one screw in the middle of the two boards that I drilled a hole for to the outside of the drum*. When it was done I put the frontside in its place.
*See picture
Step 3: The Finished Drum!
This is the finished drum!
Look at the pictures! =)
1 Person Made This Project!
  • Make It Bridge
    Make It Bridge
  • Big and Small Contest
  • For the Home Contest
31 Comments
TitoMoLe
TitoMoLe
7 years ago
I wonder, since on the front you have to put screws to tune up the Cajón... Do you think is a good idea to use thread inserts to avoid the plywood to tear down?
npanrob
npanrob
8 years ago
Thank you. It's cool.
BuildBros
BuildBros
10 years ago on Introduction
Here's the english version of those instructions:
http://www.davidbruce.net/building_cajon.pdf
theawesomeninja
The vid sound isn't the best, but I've heard these in real life, and its like half a drum set in one box! Might build one once i have time...
1spartan95
1spartan95
Reply 12 years ago on Introduction
I'm going to try it with spruce, and I'll tell ya about it when I'm done.
Awesome 'ible!!
89joho87
89joho87
12 years ago on Step 2
It was a bit tricky to tighten the snare wire! I got to metal plates as you can see in the pictue, those are tighten with two metal screws and two nuts on the inside of the drum. On the outside of the drum I only got one wingnut to tighten the whole construction. I don't find wingnuts are so sharp that they could have your leg bleedning but of course everthing can happen! Build it on yor own risk! =P
chapa-de-frente
man, this is right up my alley! i already beat on everything in sight, this is another project for me!
vvshende
vvshende
I'm also a little confused how you arranged the snare in the cajon. I much prefer this way to loose snare wires, but I don't understand how you attached the snares. Could you explain a little more?
LandMime
LandMime
So using the wing nut can you tighten and loosen the snare without opening the box? If so, I'm not sure from this photo I can tell how the strap would move. Also, have you found the placement of the wing nut troublesome? I'd hate to get my leg up against that too many times. Already looks like some blood on the side . . . :O)
strings3002
strings3002
I JUST built a Cajon! I saw one at a jam and thought,"I can do that!" It was a fun and easy build. Mine is not as loud as I may wish. My next one will be better.
Logan D
Logan D
13 years ago on Introduction
I just finished mine. I used actual snare drum tensioning devices that are inside the box and the snare is shimmed up on the edges to keep them pressed against the tapa. It sounds great, but in the future I might want to test out a traditional guitar string setup. I made mine out of crappy warped plywood I found and flattened down with a box of chains(kind of worked), some cedar scraps for an internal frame, and 1/8" birch front plywood for the tapa. I was also looking into the Marímbula idea that bigredlevy mentioned, but to do this the sound hole would have to be put on the side. Overall: really fun instrument, great jamming applications, and very easy to tweak and make interesting by adding different types of snares, wires, etc. to the inside of the box.
Logan D
Logan D
Does the placement of the snares on the drum matter? Should they be horizontal, vertical, further up or down, etc.?
89joho87
89joho87
Reply 13 years ago on Introduction
Further up, cause you want to get the snare sound further up rather than down!
Logan D
Logan D
ok, so I should be horizontal to the front of the box?
