Introduction: Renewable Energy to Power Vehicle Engine
Friends,
I have an Idea budding in my head to run engines on water as fuel.
Today, I will share my thoughts with you and provide you a good clue of what could be the solution of GAS alternative.
Friends, before starting with the instructable I want to make it clear that I haven't build anything with this idea as of now. So, I am not completely sure how far it is safe and possible.
With this in mind lets start the 'project ENVIRONMENT'.....
I TAKE NO RESPONSIBILITY OF HARM CAUSED DUE TO THIS INSTRUCTABLE.
P.S.: Those who are looking for the prototype, this instructable will not help you.
I will like to thank all those whose instructables I have used here.
Step 1: Basic Concept
The concept is to generate hydrogen from water through electrolysis and use it to power the usual petrol engine.
Electrolysis of water:
Go to my instructable on 'HHO generator' for more details.
https://www.instructables.com/id/HHO-generator/
Step 2: Supply Hydrogen Gas to Engine
Supply hydrogen generated from electrolysis to engine through the petrol intake valve.
Petrol engine uses a mixture of petrol and air to fire. Instead of petrol we will be using hydrogen.
Do not pre-mix hydrogen with air intake as it may result in explosion.
Adjust the fuel(hydrogen) pressure to get the optium result.
The engine should fire now.
Step 3: Vary Voltage of DC Supply to Control Electrolysis Process
THIS IS THE STEP WHERE I HAVE NO CLUE OF WHAT CAN BE USED TO VARY VOLTAGE.
HOWEVER, I can help you of what can be done.
Use a tachometer sensor (tachometer is used to read the rpm of motor) to read the rpm of engine. According to the rpm of engine vary the voltage of the DC supply.
For example:
when the speed increases---the rpm increases---this shld increase the voltage----this will speed up the electrolysis process.
And, when the speed decreases---rpm decreases---the voltage decreases----this will slow down the electrolysis process.
'The key is to generate only required amount of hydrogen needed for combustion.'
For example:
Step 4: The DC Supply
DC supply powers the electrolysis process....
To charge the supply, use a battery or dynamo/alternator.
Read the following instructable:
https://www.instructables.com/id/Bike-Generator/
Now, the circuit is complete.
I hope this instructable makes sense and has some appeal to it.
BEST OF LUCK GUYS! MAKE UR OWN VERSION SOON AND DO NOT FORGET TO SHARE IT!
Step 5: Update: Magentic Generator Assisted Car
this is a discussion about what are the possiblities of running a car using alternate sources of energies, specifically water and electrical energy.
lot has been debated on the HHO energy. now, lets debate over this new idea.
according to some inventors, magnetic energy can be used to produce electricity forever without any external effort. to support this, i am posting two videos which can convince that it is not entirely impossible.
the first one is very basic in nature and u can try this at home. the second one is a more commercial in nature.
