Introduction: How to Build Your Own Sugru Robot, Fixbot
So you saw our video and you've fallen in love with Fixbot, have you? That's okay, it's understandable. We've fallen in love with it too.
We have some great news! You can build your own Fixbot too, provided that you're okay with getting your hands dirty and that you have access to a Makerbot / RepRap / Ultimaker / 3D printer. You don't need to be a code wizard or a da Vinci descendant to get through this instructable, but it will help if you know a bit about how to upload sketches to an Arduino.
Join us on a journey of bearings, nuts, servos, lots of wires and some ABS, and by the end of it, you'll have your own Fixbot to play with!
P.S. we'd like to give a hat tip to David Chatting for his trigonometry skills and to Benedikt Gross for his movement learning code!
Step 1: What You'll Need
- 16 x M3, 16mm long bolts and nuts
- 16 x M4, 12mm long bolts and nuts
- 28 x M1.6, 10mm long bolts
- 3 10mm outer diameter x 3mm inner diameter ball bearings
- 4 x Hitec HS-422 servos
- 1 x SpringRC SM23/33 microservo (also known as sm-s2309s)
- 1 x Arduino
- 1 x 7.5V DC power supply
- Red, yellow and black solid-core wire
- 3 cable ties
- 2 small terminal blocks
- M4 allen key
- M3 allen key
- Pliers
- Needle file
- Wire strippers
- Small phillips-head screw driver
- Small flat-head screw driver
Step 2: Print Parts
Head over to Thingiverse and download Fixbot's STL package. You'll notice that you have a choice between two different sets of files. The first set contains all standard parts including the main chassis, the rotation axis, as well as the finger. The second set of files includes the same parts, but we've added some extra feet on the bottom layer to stop the models from curling. If you have a really well calibrated 3D printer or Makerbot, feel free to use the vanilla files. However, if your Makerbot is as quirky as ours, use the anti-corner curling feet variety.
Also, make sure you print one (or all) of the bases for the robot. You have a choice between a vertical screw-mounted base that you can screw onto anything, a GoPro compatible adapter to use with GoPro mounts, or a horizontal screw mounted base.
Step 3: Assemble Main Chassis
- Bolt one of the servos into part A. This requires four M4 x 12mm bolts and nuts
- Push one of the ball bearings into the bearing hole of a part B
- Screw part B onto the servo wheel. This requires four M1.6 x 12mm bolts and nuts
- Take an M3 x 15mm bolt and pass it through the bearing. Screw it into part A's hole until it almost reaches the servo on the other side.
- Bolt a new part A onto part B's M3-sized holes. This requires four M3 x 15mm bolts and nuts. Remember that you have to line them up in the right orientation! The edges of part A and part B should be flush.
Repeat this process of building the chassis until you have mounted 3 servos in total. You have successfully built the robot's 3 segment arm!
Step 4: Assemble Rotation Axis
- Bolt part C to the end of the arm (onto the last part A). This requires four M3 x 15mm bolts and nuts. Remember, these holes need to be in the right orientation. Part C should be centered to part A.
- Bolt the last big servo onto part C. This requires four M4 x 12mm bolts and nuts.
Your rotation axis is ready!
Step 5: Assemble Finger Axis
- Mount part D onto the rotation axis servo's wheel with four M1.6 x 12mm bolts and nuts.
- Screw the micro servo onto part D with four M1.6 x 12mm bolts.
- Screw the robot's finger onto the micro servo with a screw that came with one of the Hitec servos.
Fixbot now has a finger!
Step 6: Cable Management
The first thing you want to do is extend the servo cables. You will need 5 cables of different lengths which are progressively shorter. If you want to make your life a bit easier, you could buy servo cable extenders. However, if you don't wanna fork out extra money, just use some black, red and white solid-core wires.
Coiling the cables
- Take a yellow, a red and a black cable and put them in your battery drill.
- Tighten the chuck so that the cables are held into the drill.
- Hold the other side of the cables and press the trigger! You'll notice that your cables are coiling neatly into a nice braid.
Cut your braided cables to the 5 different lengths annotated in the picture. Strip both ends of the wires. Plug them into their corresponding servos. The longest cable goes to the finger servo, the shortest goes to the base servo.
Add some cable ties to keep things neat. Make sure you leave some slack for the wires to move around when the robot is moving!
Step 7: Electronics
Take all the red wires and all the black wires and group them together with two terminal blocks.
Next, plug in the yellow servo signal wires to pins 8 - 12 of the Arduino. The base servo (the one closest to the base) should be plugged into pin 8. The next one up should be in pin 9, etc. etc.
Finally, take your power supply's positive wire and plug it into the terminal block with the red wires. Take the negative of the power supply and plug it into the terminal block with the black wires. Also, plug in an extra black cable and run it from the black terminal block to the ground pin of Arduino.
Download the Arduino sketch from the Fixbot Github page and upload it to the Arduino.
Your robot is almost ready to rock.
Step 8: Mounting the Robot
This is the point where you have to choose how to mount your robot. You should have printed one of the available mounts from Thingiverse. The robot can be positioned vertically or horizontally. You can also use the GoPro mount converter so that you can use it with any GoPro suction cup, chest strap, helmet strap, etc.
All of these mounts attach in exactly the same way. Use four M3x12mm bolts and nuts to attach the robot to the mount.
Step 9: Software
Download the Processing sketch from Fixbot's Github page. Plug in the Arduino to your computer's USB port and run the Processing sketch. The robot should follow the movements you're doing on the computer!
Click to move the robot's finger!
There is an alternative, more experimental sketch that you can use to draw movements for the robot. The robot then executes them repeatedly.
Note: If you get an error whilst trying to run the sketch, it's probably because the Arduino is on a different port than the one that's hardcoded into the program.
Go to this line in the program:
Step 10: Extend and Experiment
Fixbot has been built to be extended and experimented on, so please feel free to come up with new ways of using it. In the video, the robot uses a moulded sugru finger tip to fix things.
You could alternatively use sugru to attach a pen to its finger. You could then use the horizontal mount to get it to draw on a piece of paper!
We want you to come up with cool ideas for Fixbot. Think of new things to attach to its finger, new configurations for the chassis or cool mounts for sticking it to weird places!
21 Comments
8 years ago on Introduction
The Fixbot should have its parts connected with Sugru, Not screws! :)
10 years ago on Step 2
Is there any way of getting the 3D printed parts without a 3D printer? If so, where at?
Reply 10 years ago on Step 2
hmmm, this is a good question.
So, you could upload the files onto Shapeways and order from them.
Alternatively, you could do a google search for 3D printing companies in your area and send the files to them. You could be very surprised about how many companies can do this. Finally, you could hit up your own social group and see if someone you know can print this for you....
10 years ago on Introduction
I am rather curious as to where you obtained those bearings from. I have looked around and can only seem to find ones that are 4mm in thickness, 3mm inner diameter and 10mm outer diameter. Would these be okay to use or does the thickness have to be smaller or bigger? I am almost ready to build this robot, just need to get the bearings.
Funny video
Funny video
i want one
11 years ago on Introduction
Awesome. Think Ill make one of these...
How married are you to the servos you have listed (i have a whole box of unused servos some where, and would hate to order more...)
Reply 11 years ago on Introduction
Hey zkus,
Most of the chassis is modelled to fit the hitec servo mount. You could see if your servos are going to fit by comparing your servo's datasheet with the hitec hs-422's datasheet.
We've also made the parametric 3D files available to the public, so you could change the designs to fit your servos!
Is there any instructable on how to build a parametric 3d file?
Sweet, love it when things are parametric (though in a format i am unfamiliar with... dont happen to have openscad files laying around by chance?) Ill check the datasheets, hopefully they just match. Cheers!
i think you are confusing parts a and be, it might also be nice to say how many of each parts you need to print off
For those of us that don't have a "cnc printer" are you supplying the frame work for this bot ? If so how can we order the parts ?
Thanks
Larry
You could cut them out of wood or plastic, or get them 3D printed from one of the many available online services.
Sweet project! Maybe I'll scale it up a bit and give it a claw!
Now that I think about it I think I'll make it a slave to my own arm! Flex sensors or kinect should be a good option...
Wow I am itching to try this now :)
That's a great idea! Keep us posted!
Very nice project. Funny and well-crafted video.
Nice Idea, and what a GREAT VIDEO !
great tip about winding the cables! this project is really well done!
Love the video! Awesome, just awesome.
