Introduction: How to Care for Your Safety Razor Equipment
You've invested the time and money in purchasing and learning how to use a safety razor. With a little bit up upkeep your razor will outlast you and your grandchildren. I've found safety razors at yard sales that are from the 1950s. Badger brushes can last 20+ years with upkeep too.
Please check out my blog at http://www.secretguidetoshaving.com/ for tricks of the trade of safety razor shaving and acne treatment.
Step 1: Take Your Razor Apart
Take your razor apart. Even with proper rinsing after use, you're still going to get some soap buildup and dirt.
Step 2:
Get a vegetable steamer pot and put your razor parts in it. Add some water. Make sure you use this type of pot. You don't want the razor blade sitting on the bottom of a pot of bowling water, millimeters from a 600 degree burner.
Step 3: Boil
Bring the water to a boil. Boil the safety razor for a 25-30 minutes. While this is going on get your badger brush and prepare to clean it.
Step 4: Clean That Brush
If you're shaving right, you're getting olive oil on your brush. Every month or so give it a good wash. Get your trusty brush and run it under some water. Add a little bit of your favorite hair shampoo. Add a drop of dish detergent. Simply swirl it around on the side of your sink. Rinse it really well, and shake it out. Nice and simple.
Step 5:
After your safety razor has been sitting in a pot of boiling water for a while remove it from the burner. Don't add cold water to the pot, just sit it off to the side for a while until you can retrieve the parts with your hands. Adding cold water instantly could damage your equipment.
Lots more tips and tricks to shaving at http://www.secretguidetoshaving.com/
