Introduction: How to Clean a Laptop Screen With Household Products
Hey, in this Instructable i am going to tell you how to clean a laptop screen using house hold products.
For the project you will need:
1.Dilute isopropyl alcohol(Step 1 shows you how to dilute)
2.Distilled water or bottled water
3.A bottle with a push top that will spray the mixture in a form of mist.
4.Cotton cloth
4.Cotton cloth
Step 1: How to Dilute Isopropyl Alcohol
Ok open the spray bottle and fill it half with isopropyl alcohol, then fill the other half with the bottled water or distilled water.Do not use normal tap water as the minerals can leave streaks and patches on your screen.
50% isopropyl alcohol
50% distilled water
DO NOT SPRAY ON SCREEN AS IT MAY LEAVE STREAKS
50% distilled water
Step 2: What to Use for Cleaning
When you have made the mixture and are ready to clean the screen get the softest cotton cloth that you can. If you can adjust the spray bottle so the mixture will spray out in a very fine mist. Spray the mixture on the cotton cloth and wipe the screen gently in a circular motion. Be sure not to put too much pressure on the cloth or press your fingers into it as it can leave streaks or marks on the screen.
Step 3: Tips and Hints
Here are some tips and hints:
1.when you are adding the mixture to the cloth use very little and wipe a small part of the screen to see what gives the best results.
2.If you have got a pure cotton cloth try wiping the screen without the mixture as it can give similar results.
3.Do not use cheap or rough paper towels as they can damage the screen.
4.Some tissues can leave some small white flakes, so avoid using these.
5.MOST IMPORTANT: AVOID USING DOG TO CLEAN LCD SCREENS AS THEY MAY LEAVE STREAKS!!!!
