Introduction: How to Connect Your PS3 Controller to Your Computer
If you want to connect your PS3 controller to your PC and play games with it, this is the guide for you
first thing you should have is an internet connection
and obviously a ps3 controller and a computer.
Step 1: Downloading the Program to Your Computer
For the ps3 controller to be connected to your computer and actually use it, you need to download a program on your computer
its called DS3 Tool
go to the following link:
http://www.motioninjoy.com/download
its pretty easy to do everything by yourself from here since theres also a tutorial and everything, so ill just write the main things you have to do
go down a little and when you find the downloads, download the latest version, or any other version you want
then click on "follow the instructions"
its called DS3 Tool
Step 2: Installing the Program and Setting Up the PS3 Controller
Then depending on the version you downloaded, click on its version number from the list
ill suppose you downloaded the latest version, so:
Click on "Latest version"
then simply start doing what the tutorial says, but skip the first point because you already did it, which is actually downloading the program to your computer
install it and then setup your ps3 controller with it
Step 3: When You're Done
After you've installed the program and set up your ps3 controller, its time to actually make it work with the game you wanna play using the ps3 controller
so simply open the game and then go to its control settings, and change each control, to the ps3 controller
for example
in a game where "jump" is done using the SPACE BAR on the keyboard, you can change it to be the X button on the ps3 controller, and so on
i hope this instructable helped
comments are welcome.
for example
