How to Control 12 Led With Uno
Intro: How to Control 12 Led With Uno
This is my first instructable and I want to thank Oadil for his instructable Trafik light, 9 led using Arduino UNO I bought a simple UNO micro controller and I was looking for an easy project to be able to understand the inputs and the outputs. Check out his instruct able to see the first steps and how to connect the led with the different outputs. I could just copy his text but I really wanna give him some credit. I spent several days before I found help.
STEP 1: Trafik Lights
int led2 = 2;
int led3 = 3; int del=1000; int led4 = 4; int led5 = 5; int led6 = 6; int led7 = 7; int led8 = 8; int led9 = 9; int led10 = 10;
// the set up routine runns once when you press reset:
void setup () { // initialize the digital pin as oupput.
pinMode(led2, OUTPUT); pinMode(led3, OUTPUT); pinMode(led4, OUTPUT); pinMode(led5, OUTPUT); pinMode(led6, OUTPUT); pinMode(led7, OUTPUT); pinMode(led8, OUTPUT); pinMode(led9, OUTPUT); pinMode(led10, OUTPUT); } //the loop routine runs over and over again forever:
void loop(){
digitalWrite(led2, HIGH); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, HIGH); digitalWrite(led9, LOW); digitalWrite(led10, LOW);
//All red
digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, HIGH); digitalWrite(led5, HIGH); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, HIGH); digitalWrite(led9, LOW); digitalWrite(led10, LOW);
delay(del*2);
// GREEN1
digitalWrite(led2, LOW); digitalWrite(led3, HIGH); digitalWrite(led4, LOW); digitalWrite(led5, HIGH); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, HIGH); digitalWrite(led9, LOW); digitalWrite(led10, LOW);
delay(del);
//YELLOW1
digitalWrite(led2, HIGH); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, HIGH); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, HIGH); digitalWrite(led9, LOW); digitalWrite(led10, LOW);
delay(del/2);
//ALL RED
digitalWrite(led2, HIGH); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, LOW); digitalWrite(led7, HIGH); digitalWrite(led8, HIGH); digitalWrite(led9, LOW); digitalWrite(led10, LOW);
delay(del*2);
//GREEN 2
digitalWrite(led2, HIGH); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, HIGH); digitalWrite(led7, LOW); digitalWrite(led8, HIGH); digitalWrite(led9, LOW); digitalWrite(led10, LOW); delay(del);
//YELLOW2
delay(del/2);
//ALL RED
digitalWrite(led2, HIGH); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, HIGH); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, LOW); digitalWrite(led9, LOW); digitalWrite(led10, HIGH);
delay(2*del);
//GREEEN2
digitalWrite(led2, HIGH); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, HIGH); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, LOW); digitalWrite(led9, HIGH); digitalWrite(led10, LOW);
delay(del);
//YELLOW3
STEP 2: Christmas Lights
Now that I understood a lille bit more I wanted to play and explore some possibilities.
Observe that the fist two columns are just the same. but I added three more outputs and tried to make it work like the christmas lights.
Copy and paste the code below.
int led2 = 2;
int led3 = 3; int del=1000; int led4 = 4; int led5 = 5; int led6 = 6; int led7 = 7; int led8 = 8; int led9 = 9; int led10 = 10; int led11= 11; int led12= 12; int led13= 13;
pinMode(led2, OUTPUT); pinMode(led3, OUTPUT); pinMode(led4, OUTPUT); pinMode(led5, OUTPUT); pinMode(led6, OUTPUT); pinMode(led7, OUTPUT); pinMode(led8, OUTPUT); pinMode(led9, OUTPUT); pinMode(led10, OUTPUT); pinMode(led11, OUTPUT); pinMode(led12, OUTPUT); pinMode(led13, OUTPUT); }
// ALL ON
void loop(){ digitalWrite(led2, HIGH); delay(del); digitalWrite(led3, HIGH); delay(del/2); digitalWrite(led4, HIGH); delay(del/3); digitalWrite(led5, HIGH); delay(del/4); digitalWrite(led6, HIGH); delay(del/5); digitalWrite(led7, HIGH); delay(del/6); digitalWrite(led8, HIGH); delay(del/7); digitalWrite(led9, HIGH); delay(del/8); digitalWrite(led10, HIGH); delay(del/9); digitalWrite(led11, HIGH); delay(del/10); digitalWrite(led12, HIGH); delay(del/11); digitalWrite(led13, HIGH); delay(del);
// ALL OFF
digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, LOW); digitalWrite(led9, LOW); digitalWrite(led10, LOW); digitalWrite(led11, LOW); digitalWrite(led12, LOW); digitalWrite(led13, LOW); delay(del/4);
digitalWrite(led2, HIGH); delay(del/3); digitalWrite(led3, HIGH); delay(del/3); digitalWrite(led4, HIGH); delay(del/3); digitalWrite(led5, HIGH); delay(del/3); digitalWrite(led6, HIGH); delay(del/3); digitalWrite(led7, HIGH); delay(del/3); digitalWrite(led8, HIGH); delay(del/3); digitalWrite(led9, HIGH); delay(del/3); digitalWrite(led10, HIGH); delay(del/3); digitalWrite(led11, HIGH); delay(del/3); digitalWrite(led12, HIGH); delay(del/3); digitalWrite(led13, HIGH); delay(del);
// ALL OFF
digitalWrite(led2, HIGH); digitalWrite(led3, HIGH); digitalWrite(led4, HIGH); digitalWrite(led5, HIGH); digitalWrite(led6, HIGH); digitalWrite(led7, HIGH); digitalWrite(led8, HIGH); digitalWrite(led9, HIGH); digitalWrite(led10, HIGH); digitalWrite(led11, HIGH); digitalWrite(led12, HIGH); digitalWrite(led13, HIGH);
delay(del/4);
delay(del/4); digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, LOW); digitalWrite(led9, LOW); digitalWrite(led10, LOW); digitalWrite(led11, LOW); digitalWrite(led12, LOW); digitalWrite(led13, LOW); delay(del/4);
digitalWrite(led2, HIGH); delay(del/5); digitalWrite(led3, HIGH); delay(del/5); digitalWrite(led4, HIGH); delay(del/5); digitalWrite(led5, HIGH); delay(del/5); digitalWrite(led6, HIGH); delay(del/5); digitalWrite(led7, HIGH); delay(del/5); digitalWrite(led8, HIGH); delay(del/5); digitalWrite(led9, HIGH); delay(del/5); digitalWrite(led10, HIGH); delay(del/5); digitalWrite(led11, HIGH); delay(del/5); digitalWrite(led12, HIGH); delay(del/5); digitalWrite(led13, HIGH); delay(del);
digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, LOW); digitalWrite(led9, LOW); digitalWrite(led10, LOW); digitalWrite(led11, LOW); digitalWrite(led12, LOW); digitalWrite(led13, LOW); delay(del/4); digitalWrite(led2, HIGH); digitalWrite(led3, HIGH); digitalWrite(led4, HIGH); digitalWrite(led5, HIGH); digitalWrite(led6, HIGH); digitalWrite(led7, HIGH); digitalWrite(led8, HIGH); digitalWrite(led9, HIGH); digitalWrite(led10, HIGH); digitalWrite(led11, HIGH); digitalWrite(led12, HIGH); digitalWrite(led13, HIGH);
delay(del/4); digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, LOW); digitalWrite(led9, LOW); digitalWrite(led10, LOW); digitalWrite(led11, LOW); digitalWrite(led12, LOW); digitalWrite(led13, LOW); delay(del/4); digitalWrite(led2, HIGH); digitalWrite(led3, HIGH); digitalWrite(led4, HIGH); digitalWrite(led5, HIGH); digitalWrite(led6, HIGH); digitalWrite(led7, HIGH); digitalWrite(led8, HIGH); digitalWrite(led9, HIGH); digitalWrite(led10, HIGH); digitalWrite(led11, HIGH); digitalWrite(led12, HIGH); digitalWrite(led13, HIGH);
digitalWrite(led2, HIGH); delay(del/5); digitalWrite(led3, HIGH); delay(del/5); digitalWrite(led4, HIGH); delay(del/5); digitalWrite(led5, HIGH); delay(del/5); digitalWrite(led6, HIGH); delay(del/5); digitalWrite(led7, HIGH); delay(del/5); digitalWrite(led8, HIGH); delay(del/5); digitalWrite(led9, HIGH); delay(del/5); digitalWrite(led10, HIGH); delay(del/5); digitalWrite(led11, HIGH); delay(del/5); digitalWrite(led12, HIGH); delay(del/5); digitalWrite(led13, HIGH); delay(del/4);
digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, LOW); digitalWrite(led9, LOW); digitalWrite(led10, LOW); digitalWrite(led11, LOW); digitalWrite(led12, LOW); digitalWrite(led13, LOW); delay(del/4); digitalWrite(led13, HIGH); delay(del/5); digitalWrite(led12, HIGH); delay(del/5); digitalWrite(led11, HIGH); delay(del/5); digitalWrite(led10, HIGH); delay(del/5); digitalWrite(led9, HIGH); delay(del/5); digitalWrite(led8, HIGH); delay(del/5); digitalWrite(led7, HIGH); delay(del/5); digitalWrite(led6, HIGH); delay(del/5); digitalWrite(led5, HIGH); delay(del/5); digitalWrite(led4, HIGH); delay(del/5); digitalWrite(led3, HIGH); delay(del/5); digitalWrite(led2, HIGH); delay(del);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
digitalWrite(led10, LOW); digitalWrite(led11, HIGH);
delay(del/4);
digitalWrite(led11, LOW); digitalWrite(led12, HIGH);
delay(del/4);
digitalWrite(led12, LOW); digitalWrite(led13, HIGH); delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
delay(del/4);
digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, LOW); digitalWrite(led9, LOW); digitalWrite(led10, LOW); digitalWrite(led11, LOW); digitalWrite(led12, LOW); digitalWrite(led13, HIGH); delay(del/4);
digitalWrite(led2, HIGH); digitalWrite(led3, HIGH); delay(del/4); digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, HIGH); digitalWrite(led5, HIGH); delay(del/4); digitalWrite(led2, HIGH); digitalWrite(led3, HIGH); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, HIGH); digitalWrite(led7, HIGH); delay(del/4); digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, HIGH); digitalWrite(led5, HIGH); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, HIGH); digitalWrite(led9, HIGH); delay(del/4);
digitalWrite(led2, HIGH); digitalWrite(led3, HIGH); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, HIGH); digitalWrite(led7, HIGH); digitalWrite(led8, LOW); digitalWrite(led9, LOW); digitalWrite(led10, HIGH); digitalWrite(led11, HIGH); delay(del/4);
digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, HIGH); digitalWrite(led5, HIGH); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, HIGH); digitalWrite(led9, HIGH); digitalWrite(led10, LOW); digitalWrite(led11, LOW); digitalWrite(led12, HIGH); digitalWrite(led13, HIGH); delay(del/4);
digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, LOW); digitalWrite(led9, LOW); digitalWrite(led10, LOW); digitalWrite(led11, LOW); digitalWrite(led12, LOW); digitalWrite(led13, LOW); delay(del/4); }
STEP 3: Forward Movement
I was thinking in a worm when I wrote this.
int led2 = 2;
void loop(){ digitalWrite(led2, HIGH); digitalWrite(led3, HIGH); delay(del/4); digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, HIGH); digitalWrite(led5, HIGH); delay(del/4); digitalWrite(led2, HIGH); digitalWrite(led3, HIGH); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, HIGH); digitalWrite(led7, HIGH); delay(del/4); digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, HIGH); digitalWrite(led5, HIGH); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, HIGH); digitalWrite(led9, HIGH); delay(del/4);
digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, HIGH); digitalWrite(led5, HIGH); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, HIGH); digitalWrite(led9, HIGH); digitalWrite(led10, LOW); digitalWrite(led11, LOW); digitalWrite(led12, HIGH); digitalWrite(led13, HIGH); delay(del/4); digitalWrite(led2, LOW); digitalWrite(led3, LOW); digitalWrite(led4, LOW); digitalWrite(led5, LOW); digitalWrite(led6, LOW); digitalWrite(led7, LOW); digitalWrite(led8, LOW); digitalWrite(led9, LOW); digitalWrite(led10, LOW); digitalWrite(led11, LOW); digitalWrite(led12, LOW); digitalWrite(led13, LOW);
8 Comments
ofir60 9 years ago
Awesome ideas!
For the next times, I'd recommend you learning about:
Charlieplexing,Shift-Register, and for loops to make less code writing/less pins.
Send me a PM if you want further explaining :)
Otech2012 8 years ago
luzm 9 years ago
Thanks! maybe it looks like a lot of coding, but I just created two rows of code and changed a single thing avery time, then I copied and pasted a lot of times. I'll try to use less pins in the future, but how can I have control over every single one? I have some sequences that may require it.
ofir60 9 years ago
for and while.
As for using less pins, you can do that using shift-register, he uses 3 pins and gets 8 outputs.
Here's an example for one.
https://www.sparkfun.com/products/733
To learn more, read these articles:
http://www.idogendel.com/en/archives/211
It has 3 parts, look at the update part below.
Have fun!
luzm 9 years ago
Oh, I understand what you mean now. I don't have shift-register yet, but I'm expecting a couple.
violinsinalma 9 years ago
Nice!
seamster 9 years ago
Coo, thanks for sharing this!
luzm 9 years ago
Thanks! I really appreciate . :-)
