Introduction: How to Convert a T-shirt Into a Bikini Cover Up
I'm sure you have the one big t-shirt that you never wear, well on this tutorial I give you an idea on how to convert it into a bikini cover up!
Step 1: You Will Need.
T-shirt.
Elastic band.
Sewing machine.
Scissors
Elastic band.
Sewing machine.
Scissors
Step 2: First Step
Let's start! It's very easy!
Picture #1: First you need to cut the neck line
Primero debes cortar el cuello de la camiseta.
Picture #2: See how I cut through unto the shoulder.
Fíjate como corto hasta llegar al hombro .
Step 3: Second Step
Picture #3: Measure the elastic band according to your size, not too tight.
Mide cuanto elástico necesitarás de acuerdo a tu medida, no muy apretado.
Picture #4: Now sew the elastic like I'm doing to secure.
Coser el elástico como lo hago en el video y así asegurarlo.´
Picture #5 and Picture #6: To sew the elastic choose the zig zag type.
Para coser el elástico, elige la forma zig zag en tu máquina de coser.
Picture #7: After you're done, will look like this.
Luego de coserlo, te quedará así.
Step 4: Third Step
Picture #8, Picture #9 and Picture #10: Measure your arm, cut the elastic and repeat the same step as you did for the neck.
Mide tu brazo y corta el elástico para luego repetir el mismo paso que realizaste para el cuello.
Picture #11 and Picture #12: Will look like this! :)
Te quedará así! :)
Now go on and steal your boyfriend's T-shirt!! ;)
