Introduction: How to Read Books on a Digital Photo Frame
How to convert (e-text) book to images and read it on a digital photo-frame
(There are also programs that can do this, more or less successful.)
My photo frame has 7" 234x480 resolution.
It does not read txt or pdf. Here is how to create images from books.
1. convert pdf to text (if necessary)
2. insert it into open office writer/ms word
3. format page
4. export to pdf
5. export pages from pdf to images
6. resize and convert images
Latest version is on http://dbojan.co.cc
3. format page
4. export to pdf
Step 1: 1. Convert Pdf to Text, and Reflow Text (if Necessary)
If your text is in pdf format, here is how to convert pdf to text:
-export pdt2txt using "somepdf 2 text" converter.
Picture 1:
1. Open program in "Somepdf 2 text converter.
2. Click on Play to convert pdf to text.
Reflow text
if your text lines break in the middle of the page use using reflow program.
Picture 2:
1. Open text in Notepad2, or plain notepad.
2. Select the shortest line you need to reflow.
3. You can see at the bottom its length. "Sel" is 9. Or count manually.
Picture 3:
1. drag and drop file on reflow.
2. Enter shortest line -1. Here it is: 9 - 1 = 8
3. Press Go.
If lines in your text are broken, but every paragraph starts with new line, check "Use empty lines as a separator".
Picture 4:
You can see fixed line.
Picture 1:
Reflow text
Picture 2:
Picture 3:
3. Press Go.
Picture 4:
Step 2: 2. Create the Template
If you downloaded template, you can skip this step.
First set measurement units in Milimeters:
Picture 1:
Tools/Options
Picture 2:
OpenOffice.org Writer, General
Measurement unit: Milimeter
Now, to page settings.
Picture 3:
Format/Page
Picture 4:
1. Width: 117mm
2. Height: 240mm
3. Set margins to 5mm
Picture 5:
Yes
Picture 6:
File/Properties
Picture 7:
Set Title
Picture 8:
Edit/Select All
Picture 9:
Set font: Verdana, 15, Align: Justified
Picture 10:
Insert/Header/default
Picture 11:
Insert/Fields/Title
Picture 12:
Edit/Select All
Picture 13:
Verdana, 11, Italic, Align: Center
Picture 14:
Click on a small arrow to change font color.
Picture 15:
Gray 30%
Picture 16:
Insert/Footer/Default
Picture 17:
Insert/Fields/Page Number
Picture 18:
Add /
Picture 19:
Insert/Fields/Page Count
Picture 20:
Edit: Select All
Picture 21:
Set font: Verdana, 11, Align: Center
Picture 22:
Click on the arrow to change font color
Picture 23:
Set font color to Gray 30%
Picture 24:
File/Save As
Picture 25:
ODF.
Picture 26:
Click on Save
You can also delete text, change title, and save file as template.odt.
Note: You can save as Microsoft 97 doc, but header and footer font settings will not be saved.
Picture 1:
Tools/Options
Picture 2:
Picture 3:
Format/Page
Picture 4:
1. Width: 117mm
2. Height: 240mm
Picture 5:
Yes
Picture 6:
File/Properties
Picture 7:
Set Title
Picture 8:
Edit/Select All
Picture 9:
Picture 10:
Picture 11:
Insert/Fields/Title
Picture 12:
Edit/Select All
Picture 13:
Picture 14:
Picture 15:
Gray 30%
Picture 16:
Picture 17:
Picture 18:
Add /
Picture 19:
Picture 20:
Edit: Select All
Picture 21:
Picture 22:
Picture 23:
Picture 24:
File/Save As
Picture 25:
ODF.
Picture 26:
Click on Save
Step 3: 3. Format the Page
3. format the page
If you downloaded template, open it in Open Office, paste text into it, and change file/properties.
Picture 1:
Paste text into template.
Picture 2:
Go to File/Properties
Picture 3:
1. Set Title.
2. Press OK.
Picture 4:
-To add space to the first line in of the paragraph
1. Select all text, (ctrl+a), and move "top, inverted triangle" to the right.
Picture 1:
Picture 2:
Picture 3:
1. Set Title.
2. Press OK.
Picture 4:
Step 4: 4. Export Text to Pdf
4. export text to pdf
in Open Office:
Picture 1:
-File/Export as PDF
Picture 2:
-Click on Export.
in Open Office:
Picture 1:
-File/Export as PDF
Picture 2:
-Click on Export.
Step 5: 5. Export Pages From Pdf to Images
Download pdfxviever
Click on "Portable ZIP" and "download now" button, on the right. It will download free version.
Open file in pdfxviever
Picture 1:
-File/export/export to image
Picture 2:
-"Page range": all
Picture 3:
1."image type": JPEG
2. Click on "Options":
Picture 4:
1. "image type": True Color 8bpp
2."jpeg quality": 90
3."horizontal/vertical DPI": 300
Press OK
Picture 5,6,7,8,9
1. Enter "sh-" without quotes, and select "Auto-Number" ,add -, and "Page Number" from macro button.
Picture 10:
1. export mode: "Save each page to different image file"
2. resolution: 300 dpi
3. Click on "Export" button.
Download pdfxviever
Picture 1:
Picture 2:
-"Page range": all
Picture 3:
Picture 4:
Press OK
Picture 5,6,7,8,9
Picture 10:
Step 6: 6. Resize and Convert Images
Open file in irfanview
Picture 1:
-"File"/"batch conversion/rename"
Picture 2:
1."add all" files
2."Use this directory as output"
3."Output directory": (add "newbook" without quotes to the end of path)
4."Batch conversion"
5."Output format": jpg
6."Options":
Picture 3:
1.Save quality: 90
2. Press OK
Picture 4:
1."use advanced options"
2."set advanced options"
Picture 5:
1."resize"
"set new size"
"set both sides to"
"width": 568
2."rotate left"
3. Pres OK.
Picture 5:
-press "start" button to start
Picture 1:
Picture 2:
1."add all" files
6."Options":
Picture 3:
1.Save quality: 90
2. Press OK
Picture 4:
Picture 5:
1."resize"
"set new size"
"set both sides to"
"width": 568
2."rotate left"
3. Pres OK.
Picture 5:
Step 7: Copy to Folders
You can use batch file to copy files in group of 50 to directories.
"Copytofolders.bat" is in this zip file: http://dbojan.50webs.com/howto/template_7_inch_screen.zip
Copy it to the newbook directory, and start it.
You can edit "Copytofolders.bat" file, and change number of files that will go in each directory, if you want.
Remember to copy files to SD card/USB stick using free commander or some other utility that copies files starting from file number 1, otherwise device will display files out of order.
Press eject when done working with SDcard, or safe remove USB stick.
Use frame photo frame remote or keys on the device to move to the next page (image).
