Introduction: How to Copy PDF to Word
PDF primarily is a portable reading and display format. It looks the same as the original on whatever operation systems you view them. When surfing on the internet, we may find that most of files are in PDF format, such as government reports and academic papers. However, the non-editable feature attaches great security to PDF. In another word, copy or paste are not intended or even initially implemented. Thus more and more people wonder how to copy PDF to Word, as we often need to quote the useful content in it and familiar with editing in Ms Word.
Here I want to talk about some methods to copy PDF to Word.
Previously, if you wanted to copy PDF file to Word, you would have to use the print screen function and crop the image in another program. This involves much manually manipulate when you have a large chunk PDF to be done. However, it is possible to simplify it with the snapshot tool in Adobe Acrobat.
Open the PDF you want in the Adobe Acrobat window and then find the Snapshot tool icon in the menu bar at the top of the window (it looks like a camera). Notice the latest adobe acrobat 9 version has it you can directly copy from PDF to Word at the location you would like to place by clicking “ctrl+ v” within the Word document. The PDF will be inserted into Word as image file.
But this method has disadvantages that it’s useful to PDF without restriction and you can’t further edit it in Word document for it is image file.
Hence, actually the first and the best way you should think about are to copy PDF to Word with the PDF to Word Converter
The converter can remove the password automatically in the process of conversion. And convert the files to editable Word files for your further reuse.
Following is the tutorial you will copy text from PDF to Word successfully in a short time:
Step one: Download and install the PDF to Word Converter, then launch it. An intuitive interface will appear. Click “Add files” to import the PDF files you want into the panel.
Step two: Choose the output type to Word format and select the page range option or type in page range if needed. Don’t ignore to define the output folder path.
Step three: Click the “Convert” to start conversion. The PDF files will unlock and converted to Word files rapidly!
After conversion you can copy PDF text to Word or any other content like image, hyperlinks graphics and so on easily. Or you can insert the whole page by the add-in function of Ms Word-"Insert" with the converted Word files. To copy PDF to Word will be a piece of cake with the PDF to Word Converter.
