Introduction: How to Create Multiple Hoop Earrings
About: Jane Chew aka XQDesigns is the chief editor behind 2 popular jewelry making blogs and websites: Handmade Jewelry Club and DIY Lessons. She started jewelry making as a hobby few years ago and was amazed how she…
Earring hoops are a fad! Here's one you can try and create one for you and your friends.
Materials & tools:
Beading wire
2 Crimp beads
32 White beads
14 Green beads
2 Heart charm
2 Ear wires
Flat nose pliers
Wire cutter
Step 1:
Cut 20 inches beading wire. Slide in a crimp bead, followed by your beads. You can choose to slide in the bead in any order you want. Then insert the beading wire back thru the crimp bead and pull the wire to create a hoop.
Step 2:
Slide in 8 beads then insert the wire back thru the crimp bead. Pull the wire to create a 2nd hoop.
Step 3:
Now slide in 12 beads and the heart charm.
Step 4:
Insert the wire back thru the crimp bead. Adjust the wire to create perfect hoops, making sure the crimp bead is at the center. Press the crimp bead.
Step 5:
Attach your ear wire and you're done!
As always, I have a detailed pictoral step by step PDF copy available for free at DIYLessons.org.
