Introduction: How to Cut a Rope With Itself
If you not have a knife or scissors just use this lifehack and cut a rope where ever you want. This also usable in emergency or on a camping trip!
Step 1: Watch the Video
Thin is easy thick is hard but works ;)
Step 2: #1
Take the rope and step on each sides. Leave it loose between your legs. The cutting point will be on the middle between your legs.
Step 3: #2
Take the other end of the rope under the loose part between your legs and start pulling the upper part of the rope alternately. That was a nearly half inches or 12 mm rope so it's sweaty :)
Step 4: The End
It was interesting to try this solution and saw this really working. In case of emergency or just want to do some exercise give it a try ;)
That's the Shiftyway
Step 5: Don't Forget to Check Out the Video
As always thanks for your support
