Introduction: How to Divide Work on Knitting Machine
When you are knitting a sweater, when you come to the neckline, you have to divide the work. In hand knitting you just do not work one of the part, in machine knitting it's a bit different., because you can't just "stop knitting there".
Step 1: Cast Off
Cast off the central part of the neckline. In the case in the photos, I did it with a different colour because those stitches will be picked up later to hand knit the hem (by my sister).
Step 2: Nylon Yarn
Using the nylon yarn (or another yarn, I prefer nylon yarn because it moves smoothly), do stitches by hand, pulling the needles as back as you can. This way the stitches on the nylon yarn will be not worked. Keep the nylon yarn out of the way of the carriage.
Step 3: Work First Part
Work first part as you do normally. Cast off.
Step 4: Nylon Yarn Off
Pull carefully the nylon yarn until the previous stitches are back on the needles and all the needles are in the working position. Go on working this part and cast off!
Note that you can do the left or the right part first, it depends on what you prefer, but I suggest to note which part you start with the carriage. If you start at right (as me) it will be better to start with the right part. If you start with the carriage to the left, start with the left. Doing otherwise, you risk to mess up with the unworked part. :)
Vote, if you like! >^.^<
