Introduction: How to Do a Vitrigraph Pull -or- How to Play With Molten Glass
Step 1: Ingredients
Compatible glass
A small kiln with layers that can separate, or a kiln specifically used for Vitrigraph
Kiln temperature controller
Permanent marker
Box cutter
Hammer
Heavy leather gloves
Eye protection
Round file
Needle nose pliers or similar
Long tweezers (12” or so)
Diamond shears or a cheap pair of scissors
Clothes made of natural fibers
Step 2: Disclaimer
Step 3: Prepare the Flowerpot
Widen the hole in the bottom with the rough round file. These can be purchased at Harbor Freight for cheap. I made my hole about ¾”. Rasp from inside and outside, only pushing down on the rasp when on the away stroke, and then clean out the pot of any red dust. Don’t breath the dust, because it has silica in it = bad for your lungs.
Step 4: Fill the Flowerpot With Glass
To safely break the bottle, wrap it several times. I used a handy Ikea bag and a huge tshirt. With eye protection on just in case, hit the bottle through all of the wrappings with a hammer. My wine bottle was surprisingly thick and hard to break, and I used a small sledge hammer. It took 5 blows, but when it finally did break, it was quite satisfying. It is loud hitting it with the hammer, but rather dull sounding when it finally goes. Carefully unwrap your broken glass bottle, and then with “dull” slow fingers, carefully arrange the broken glass in the flower pot as dense as possible. Take a relatively larger piece and set it across the hole in the bottom to prevent small shards from falling out. Vibrating the pot settles the glass so you can fit more in.
Step 5: Prepare the Hardibacker
Guesstimate the center, and make a hole about 1 ½” across. I used the flowerpot to measure where I should put the hole, the marker to copy the inside hole, and drew a larger hole around the marker outline. Next, carefully cut with the box cutter on the line, just to break or score the surface. Use the hammer to break the hole out. Punch it out from both sides, and use the box cutter to clean up the edges of the hole. It doesn’t have to be perfect, just not too big or small. Too big and your flowerpot could fall through, too small and it will touch the glass coming through.
Step 6: Prepare the Kiln
My school, Utah State University, happened to have these handy metal brackets on the wall to use as a shelf. Since we are pulling molten glass out of the bottom of the kiln, it needs to be off of the ground, and not have the bottom blocked. It is best to do this over a cement floor, since the glass can break and send hot glass skittering to unintentional places. It is important to have it very secure, including the plug/extension cord. If the plug/extension cord is anywhere that it could be tripped over…TAPE IT DOWN…you don’t want the whole kiln pulled off of the shelf while hot and live with electricity. Molten glass is conductive, not to mention the huge mess and possible personal damage that it could do.
I used two steel angle irons and two kiln bricks to prop the kiln on top of, and the extension cord runs along the wall out of the way of foot traffic. I highly suggest the kiln bricks as support across the bottom of the Hardibacker. I am fairly sure they are the only reason that I did not lose the first pot to the breakage of the thin Hardibacker.
Stack everything together. My stack = angle iron on shelf brackets, two kiln bricks set perpendicular on the angle iron with a gap large enough to pull the glass through between them, two pieces of Hardibacker with the holes lined up and centered on the gap between the kiln bricks, the flowerpot full of glass centered on the hole, the kiln ring with the elements, and the lid. Make sure that the flowerpot and the glass are not touching the lid because it will end up sticking and eating into the kiln brick of the lid.
Step 7: ***Extension Cord Safety***
Step 8: Bring the Heat
The heating schedule that we need to go by is:
Raise 425 degrees Fahrenheit every hour to 850 degrees Fahrenheit
Raise the temperature as fast as possible to 1550 degrees Fahrenheit to avoid devitrification* of the glass
This takes me about 2 and a half hours.
*Devitrification is when crystal growth happens on the surface of the glass, making it cloudy and in general is not desirable.
Step 9: Pull Out Hot Glass –or- It’s Getting Hot in Heeerre, So Pull on Some... Glass?
Once the kiln gets up to 1550 degrees Fahrenheit you can start testing the glass. With eye protection and heavy leather gloves on, use the needle nose pliers and attempt to grab onto the cooler plug of glass sticking out of the bottom of the flower pot. Raise the temperature slowly (letting the heat soak in for 10 minutes every 25 degrees you raise the temperature), until you can grab and squeeze the cooler plug and pull the glowing glass down.
1600 to 1650 is about as high as you should be going, but up to 1700 is okay. Keep in mind that it takes time for the heat to soak through the glass mass. In other words, if you ramp up the temperature too fast, say from 1550 to 1650, the glass on the top is going to heat up faster than the glass on the bottom that is exposed to the colder environment outside of the kiln. Once the heat starts soaking into the colder lower mass, it will start to move, and then start moving faster and faster, out of control since the glass on top is already very hot. If the glass ever gets too fast, lower the temperature on the controller, and if it is really out of control, you can quickly lift and replace the lid of the kiln to flash cool. Be Careful if you decide to do a flash cool, hot air rises quickly and can burn your arm or face off in the process. The kiln lid will be really hot as well, so have on protective gear.
Pulling the glass out faster will make it come out thinner, slowing down will make it come out thicker. You can use various tools to manipulate the glass, I chose two long tweezers because they were easier to manipulate with the heavy leather gloves on.
Pay attention to where the hot glass is, and it is all hot! It is easy to get carried away and twist the glass up close to the gloves or your arms. Even if it is not glowing, it is over 900 degrees, and can still give you a wicked burn.
Step 10: How Do I Get This Thing Off???
Step 11: Finishing Up
You may be able to handle some of the glass that you pulled; it might be cool enough not to burn when picked up. Use your discretion, and hover your hand over anything/lightly touch before committing to the full pickup.
Step 12: Glass Breaks
Step 13: Miscellaneous Information
For bottle glass=
Soak at 1030 degrees Fahrenheit for 20 to 30 minutes, then lower by 100 degrees per hour to 700. Turn off the kiln and wait overnight to open. The glass may still be hot even overnight. If it is, take off the kiln lid and let it air cool until you can touch it. If it is too warm and you pick it up, it can still thermally shock and break, possibly cutting you, so wait till it is cool.
Step 14: The End... or Is It?
http://www.lampworketc.com/forums/
http://www.talkglass.com/forum/forum.php
http://www.wetcanvas.com/forums/forumdisplay.php?f=89
https://www.bullseyeglass.com/education/free-videos.html
