Introduction: How to Do an Unique Multi-wrap Dress
1- Two meters of Lycra
2- Scissors
3- Sewing machine
4- Accessories, ribbon, elastic band of a different color.
Step 1: First Step
Fold by length the fabric, measure about 42 cm and then cut all the way
Step 2: Second Step
Then you have to measure from your waist to the knees.
Mark on the fabric so then you can cut and sew. This is the bottom part of the dress as you can see in the pictures.
Mesure around your waist the elastic for the next step.
On one side fold and sew for the elastic and goes into the part you just sew (as you can see in the picture) Once is in, sew the tip of the elastic.
Step 3: Third Step
Add the other piece of fabric for the top, once you added sew carefully :)
Extend it and measure the piece on the midle then cut.
That's it for the third part ;)
Step 4: Fourth Step
Now learn the different ways you can wrap for many ocassions! ;)
Make a cross on the back then go back to the front defining the waist an tie on the back.
Step 5: Fifth Step
Continuing, do the same but this time covering a little of the shoulders :)
Step 6: Sixth Step
Other option is like the first picture, making like a Top.
Tie on the front then go around your waist.
Step 7: Seventh Step
Roll the fabric to make one shoulder and tie the same way.
Step 8: Eigth Step
Now cross around the neck and tie.
Step 9: Ninth Step
You can make a nude also and the same way :)
Step 10: Tenth Step
Finally you can add a ribbon of a different color, or make it like a strapless to wear with jeans! ;)
