Introduction: How to Easily Play Music With Buzzer on Arduino (The Imperial March - STAR WARS)
Hi,I recently designed a sort of "library" in order to make easier to play exact notes on arduino with the buzzer.
I included the frequencies of the notes (pleasant to be heard) with #defines .
I then defined the value of the BPM ( you can modify it obviously) and according to that I defined the note values
( the most commonly used ones).
With this defines you can easyly play a note with the command "tone" like this:
tone(pin, note, duration)
eg:
tone(8,LA3,Q);
delay(1+Q);
the delay is important because thanks to that the note doesn't overlap possibly with the successive ones.
(the "1+" is one extra millisecond that i usually put to separate notes but you can avoid it if you prefer the notes to be continuous.
Here is the code:
ARDU NOTES
(http://tny.cz/d1a629c1)
Step 1: Example: the Imperial March
With a lot of effort I did it!
I wrote the code for the first part of the imperial march... so cool !
HERE IS THE CODE:
The Imperial March
and a video that I made:
Step 2: Well Done !
Now is your turn , make your arduino "whistle" all kinds of songs!
Hope you enjoyed this instructable !
7 People Made This Project!
- Urti made it!
- Yolo Pigeon made it!
- ArifSae made it!
- Syntaxian made it!
See 3 More
31 Comments
7 years ago on Introduction
AWESOME
1 year ago
"Impressive...Most Impressive" - Darth
5 years ago on Introduction
i made this. thanks
Reply 3 years ago
Very nice...
Reply 5 years ago
hey Nurullah, how did u connect buzzer with lcd & what was the code?
Please help...
Thank You
3 years ago
THANKS A LOT
4 years ago
THANKS !!!!
4 years ago
thank you so much! now i so excited
4 years ago
its 2016 almost 2017 now. the current version of the arduino ide is not compatible with the code. what version of the ide are you using
4 years ago
Thanks! Work perfect!! Im happy now hahahaa
4 years ago
Thank you very much for this tutorial! It helped me to build my own tone system (which is fully compatible with millis), using yours as reference.
4 years ago
Excellent! Thanks for the nice job, it gave me an excellent Friday night! ;)
4 years ago
Thanks. I am trying this. Just a humble suggestions, if a name of buzzer pin is used instead of 8 at all places, it would be easier to change buzzer pin. (using find and replace to do so). Thanks for sharing.
4 years ago
Thanks man, that is awesome!!!
5 years ago
Thanks dude, pretty good library!!!
5 years ago
Yes it works on Arduino, just made this!
5 years ago
does it work on the arduino UNO?
5 years ago
Thank you man. This is so funny and simple.
5 years ago
This is freaking awesome!
5 years ago
Nice. However, if your code used a variable (or constant) for the buzzer pins, it would be a LOT easier to reuse in slightly different setups. For example the Sparkfun Protosnap comes with buzzer prewired on Pin2.
This is good coding practice - "Avoid Magic Numbers"
