Introduction: How to Extend Printrbox X Axis
How to extend your x axis printer area , so you can print larger objects.
Step 1: Tools&Materials
Rods:
8MM Diameter, 3' Long
http://www.mcmaster.com/#
Rod support:
http://www.thingiverse.com/thing:121820
Heavy!! Fishing String:
(some sports store, needs to be ~100lb)
Screw x6 - use the ones that came with the printer
Screw Driver
Hammer
metal plate -light weight
Wood plate - lightweight
Spring x4 - the one that came with the printer
Lubricant
Step 2: Build
Step 1:
Use a hammer to hammer in one end of the rods into the rod support.
Step 2:
Lubricate the rod and place it in the cylindrical ball bearing sliders.
Step 3:
Hammer in the 2nd side of the rod support.
Step 4:
Hook the fishing line on both ends of the rod support and make it taught.
Step 5:
Place the wooden board then the metal board with springs in between them. Then screw the platform in with the rod supports.
Step 6:
Calibrate the max X size of the print and calibrate the height of the printer.
Step 7:
Then you are dinished and ready to print large objects up to 1.5 ft.
