Introduction: How to Fill Out a PDF Form
The network coverage and development of information technology bring us a paperless environment to communicate or interact. You just need an electronic document to transmit across web. So PDF file is the dominate media to achieve that.
Why? Because the PDF file can accommodate various documents and exist without requirement of platforms, every time it displays and prints the same as original. Then you will find the very first thing of job hunting is likely to fill in a PDF application. The invoices, registration, visa applications or DMV forms, etc are in sharp of PDF files.
However, when you want to fill out a PDF form as usually do in a word doc document, you will be stuck with the scenario that you can't type on the form field even you locate the cursor right there.
Yup, this is the touted feature of PDF format and also drawback in the case of filling in PDF is that not easy to edit. What can we do next?
Some of people may print them out and fill out PDFs by hand or on a typewriter, then scan back into the computer. This is really cumbersome to go and the finished form never looks better than neat typing. As a result, it may be bad for your acceptances.
So here I want to introduce you a tool which helps fill out a PDF form is a smart PDF editor.
It converts the PDF file to an editable condition and enables you to add text to the form field. It's one of its functions I found when using. It can alone serve as a PDFfiller I think.
How to fill in a PDF with the PDF editor tutorial:
Free <a href=”http://www.convertpdf.org/edit-pdf-file.html”> download the PDF editor </a> and then install and run it. Choose form-filling mode.
First step: Import
Click "Files" in the navigation then "Open" to import your PDF form. If your file has interactive items, it will ask you if you want remove it.
Second step: Fill out PDFs
As you hold the mouse over the form, it will auto detect and highlight the areas to fill-in, isn’t cool? Then you can click on the highlighted area to start typing into it. You can also hold control key to create a box to write into it. Use a desired font style is OK.
If there is a check-box under the mouse, it will change to a pointing hand to allow you to mark it with an X. Twice click to remove it.
Final step: After you have succeeded in filling in PDF form, don't forget to save the filled-in form. It will preserve the changes in the original PDF file. So your forms are now can be viewed and printed by any PDF readers.
Actually you can fill in a PDF no matter it is a form or not, the editor has text tool to allow you modify the existing text, add or delete.
More how to <a href=”http://www.convertpdf.org/write-on-a-pdf-file.html”> write on a PDF file </a>
You can even edit PDF security to protect your PDF files from editing, printing, copying and opening. The PDF standard security consists of owner-password and user/open password.
Apart from PDF form filling, you can explore more functions of it to do with your "read-only" PDF files.
First step: Import
