Introduction: How to Fix Burnt Traces on a PC Motherboard
About: I like to modify things, make things, and modify the things i make. im no math whiz or someone with perfect grammar, but i am good at making things. at my school ive taken the welding, machining, mechanics an…
In this instructable, I am going to show you how I fixed a trace on my motherboard that had burnt off as a result of a faulty fan.
First a story...
So I had gotten a new fan for this motherboard, and intended to use it in teh new PC I was building. I plugged the fan in, and when i pressed the power switch, my test setup released a fair amount of the magic blue smoke from the underside of the board, the fan connector looked fine.
Upon further investigation the +12v line was burnt between the fan and the ATX connector, but the computer still worked fine. This needed repairs if I wanted to add a second fan.
I had also noticed after attempting to brush of the problem and just using the board that the PCI slots and possibly even the AGP slot had been rendered useless. My video carrd was PCI and it didn't work until the board was fixed.
DISCLAIMER:
I am in no way responsible for any further damage inflicted on your motherboard or any damage or injury inflicted upon people around you, yourself, or your tools whilst following the procedure depicted in this instructable. FOLLOW THESE INSTRUCTIONS AT YOUR OWN RISK.
Step 1: Tools, Materials and Precautions
For the process in this instructable, the tools you will need are:
-A soldering iron, make sure it has a good tip because you will be doing some small soldering.
-an exacto (box cutter) knife or a flat screwdriver, you are going to need to scratch some of the enamel coating away so you can solder.
The materials you will need are:
-Wire, I used some thin wire from a Hard drive cable
-Solder for your sodering iron
-Tape to hold your wires down
Other things you will need are:
-A PC motherboard with a burnt trace
-A fan (if the fan isn't spinning as a result of the burnt trace)
Precautions:
-Make sure that you unplug the power supply from the wall and press the power button. the computer will drain most of the remaining power and it will be safer to work with
-Be careful. Try your best not to damage any of the components on the board.
-Protect the parts. Remove any removable parts on the board, like the RAM, CPU, andany accessory cards you may have plugged in.
-Unplug all of the cords. You dont want to accidentally burn yourself with your soldering iron while you are fighting with cords to move them out of the way.
Step 2: Prepare for Soldering
Plug in your soldering iron, and get that board ready for soldering!
First you will need to scratch the enamel coating off of the motherboards traces that you want to solder to. If you are just soldering from solder pad to solder pad, then just skip this step. If you are not, keep on reading, I recommend you continue reading even if you aren't soldering to the traces.
Start at one end of the trace.
Follow the trace and find the end of it as well. It was easy for me because it was fairly wide, this may not always be the case.
After you found the start and the end of the trace, find the spots on the trace where the trace was burned through.
Before and after the burn spot, scratch away some of the enamel coating by taking your exacto (box cutter) knife or screwdriver and scratching at the trace until you see silver or a gold/ bronze color, DONT scratch any more, you have now made a spot you can solder to. repeat this for every spot you need to. take into account any spots where the trace passes through to the other side of the board, make sure that these stay connected too.
On to the next step.
Step 3: Solder It Up
Now that your soldering iron is hot, and the board is ready, lets get to soldering the wires on.
It helps to tin the wires and the spots that you are going to solder to before you solder them together.
There are plenty of instructables on soldering, so instead of redescribing that, I'll just get to the point.
Solder the two ends of each wire to their respective spots, when you are done, you should have the burnt spot bridged by a wire, recreating the connection that was burned away.
Now all that is left to do is tape the wires down so they dont get in your way in the future.
Step 4: Test Your Handiwork
Now there is the moment of truth.
Plug everything back in, including a fan (not the one that burnt the trace) and turn it on. If it all got soldered all right then it should turn on.
If it released the magic blue smoke again then either you might have soldered to the wrong spots or maybe the fan burnt the wires instead of the traces this time.
If smoke was released again, make sure you are using a known-good fan, discard the bad fan, you certainly dont want it to trouble you anymore. Then recheck your solder spots, you may have soldered to the wrong spots on the board.
If a known-good fan didn't work, then recheck your solder spots, some may have not been rigid enough and broken off, resolder them.
If it still didn't work then there may be a problem deeper inside theboard that you will need more than eyes to see.
I hope that this instructable proves useful to someone and helps plenty.
