Introduction: How to Fix Your Leaking Fork Seals on Any Dirt Bike or Motorcycle With Seal Mate
Sealmate is specifically designed to fix your leaking fork seals on all types of motorcycles, dirt bikes and mountain bikes. Often times fork seals get replaced even though they do not need to be instead the dirt and debris needs to be removed from the seals. Seal Mate is the only tool that will safely remove the debris. For only about $5 you could save hundreds also the time and effort it takes to replace them yourself or the downtime for bringing it into the shop. Visit www.sealmate.net
4 Comments
7 years ago
made one out of a bus card and it worked for about a week. kind of half assed it too so im guna give it another shot
8 years ago on Introduction
This is actually a pretty cool idea, I made one out of a plastic 2L bottle and it worked.
★★ Signature: ™ 007 Bike License Plate Hide Flipper ™★★
9 years ago on Introduction
It doesn't 'fix' the seal, it removes debris causing leak or pushes some into fork so it wears out faster
The majority of fork seals have at least 3 'lips' to seal against the fork tube plus a double lip dust seal
There is only one way to fix seals, replace them. Part of the cost is the amount of work involved in changing seals in cartridge forks plus you really do need special suspension fluid for forks to work properly.
You could probably make one from an old credit card for free
11 years ago on Introduction
Can this work for a mountain bike fork? Or is there a different product for that?
