How To: Format Your SD Card Back to the Original Size (WINDOWS)
Intro: How To: Format Your SD Card Back to the Original Size (WINDOWS)
- SIMPLE PROCESS: step 1 - SD Formatter
- ADVANCED PROCESS: step 2 - DiskPart
STEP 1: SIMPLE PROCESS: SD Formatter
1 - Download and install this software (from the SD card Organization) :
https://www.sdcard.org/downloads/formatter/
2 - Open the program, and select the right drive (in my case is G:), after that just click "FORMAT"
3 - You have just formatted your SD card! CONGRATULATIONS
STEP 2: ADVANCED PROCESS: DiskPart
1 - Go to the windows start button, write diskpart and press "enter"
2 - Wait a few seconds and write on this order:
- "list disk" - shows you the disks that are currently connected to the computer;
- "select disk X" - substitute x with the number of the disk
- "clean" - deletes all the data in the SD (you may have to remove and reinsert the card after this step)
- "create partition primary" - creates a partition in the sd
- "format quick" - makes a quick format
106 Comments
MarcoK1 9 years ago
Thanks. I saved may 64 GB SD Card.
steven.gagne.37051 9 years ago
Thanks a bunch to the person who made this! just saved an 8gb card from the trash :D
magamig 9 years ago
Glad I could help (:
SoniaWhoTinkers 9 years ago
thanks for creating this! i have a stack of cheap sd cards that we're going to try to breathe a bit more life into them by trying this. otherwise, we might go toward making some cool accents for crafting projects.
anton.shevelko 3 years ago
iring2x 4 years ago
ΧωρίςΌ 5 years ago
Did not work. Both SD formatter AND diskpart fail to execute because of an error and "could not find the sector requested". This is not an instructable! This is what worked for you which definitely does not solve the problem of a corrupted MBR on the SD card.
AndrewG277 5 years ago
Thank you. This worked perfectly with diskpart.
NikosC7 5 years ago
Perfect! Thank u so much!
Sangee_th 5 years ago
МишаР2 6 years ago
Thank you!
My dash camera had made my 32Gb card into a 100Mb )
Easy fix, thank you for the guide.
GeoffreyL16 6 years ago
I wish I could say this worked but I can't because my system STILL can't see the SD card. I'm using Windows 10 and it seems from the literally thousands of users of that OS, that NOBODY can see a 32 GB ScanDisk card. I wasted an hour on a chat with one of their reps and he didn't have a clue either. Not sure what my next steps are. Just an FYI, I need the large storage because I'm using the card with a Raspberry P1 3 in tandem with a 3D printer set up.
cyberhelp 6 years ago
struggled for a couple of hrs with this as well. Tried LLF, Diskpart, SD formatter, HD Recovery tools, Rufus, HP USB formatter... finally decided to try my SD to USB adapter. Used Rufus to format as Fat32/4096 and sure enough, Windows 10 recognized it as 32GB.
sumanm2 6 years ago
XroK 6 years ago
Thank you so much! You saved my 15 GB MicroSD Card!
GeorgO1 6 years ago
Salamat po!!!
MohammedTahirP 6 years ago
Thanks A Lot magamig you saved my 64gigs and Solved my error on win7
safwatammar 6 years ago
wonderful, did it successfully, thanks a lot
john.chow.773776 6 years ago
followed the instructions everything went along well
but my 64 gig sd card still says 27 gig
ideas thank you
VincentS103 6 years ago
Godsend!! Saved my 64GB SD card. More strength to you mate!! Took just a few minutes to get out of misery!!! Thank you!!!
