Introduction: How to Get MODS in MCPE
So you want some free, easy to install, fun mods for pocket edition minecraft, but you don't know how to do it or where to start. Well, now you are going to learn. First off this is for kindle and android, I'm not sure if you can get this on iOS so check and see if you can. Reason for this being it is available only on some of their devices. So, without further adieu, lets get started.
NOTE: READ ENTIRE INSTRUCTABLE BEFORE DOING THIS(nothing bad but it might screw you up if you don't)
Step 1: Download Block Launcher (it's Free)
So first you need to download Block Launcher from the app store.(if you have a kindle you will need a file opening app also)
Step 2: Kindle Fire File Explorer
This a good app for opening files, it is called File Manager for Kindle Fire.
Step 3: Download Mods
This mod is nice, it's called desnoguns. It adds tons of weaponry to your game and juggernaut armor...... and "much, much more!!" Pretty much all guns are insta-kill for passive mobs so yah....(happy hunting).... also the best gun, in my opinion, is the explosive mini-gun. Here is the link: DesnoGuns Mod
Step 4: Move Mods
Ok so if you have gotten this far you're doing good, you are also getting very close....
Now what you need to is open up you file opener and find the mod you downloaded. (should be under downloads, duh) then unzip them. Place those files in the games folder (or not, though if you place them there they will be easy to find)
Step 5: Find Mods With Block Launcher
Follow the captions on the pics, its just tapping on stuff. If you get lost here is what you do:
1. Tap on the wrench
2. Tap on the icon that says manage mcpe mod scripts
3. Tap on local storage
4. Press the icon that says "Import"
5. Tap on the folder you put the file in
6. Tap on this "mod" folder (it will sometimes place it here)
7. Tap on this folder then you are done with this step
Note: the mod should appear in the manage mcpe mod scripts folder; make sure the mod text is in bold. This means it is enabled, long press on it and tap enable to turn it on
Step 6: Texture Pack
Ok so you got the mod part down, now you have to get the texture pack in there so it will work right. Follow the info on the pics they will tell you what to do; it's basically the same thing as the last step.
Step 7: Sounds
There should be a thing that pops up and says something like: download sounds? press yes and it will download then you should be good to go. NOTE: Make sure the mod is enabled if not just long press on it and tap enable
Step 8: YOU'RE DONE
have fun with your mods and go create some mass mayhem in minecraft! For crafting recipes and other useful things go to the desnoguns website. The link is on step 3. tell me how you did and leave any feedback in the comment box :D
NOTE: if you go on one of your worlds with the mod from block launcher and use all your iron on guns then go on the normal minecraft app you wont have any iron or mod items in any app. so it's not my fault if it happened to you (this will also happen if you disable the mod)
