Introduction: How to Get a Screenshot Through SSH
I needed a quick and easy way to have a screenshot with a simple command from SSH console.
This is the result of 10 minutes of work that uses only freeware and is easly usable onder all windows that can run a SSH server.
Step 1: For This to Work You Need the Folowing Applications :
- sleep.exe (from WAIK KIT)
http://www.microsoft.com/download/en/details.aspx?id=10333
- tiny.exe (a very small and simple web server)
http://en.kioskea.net/faq/2568-tinyweb-server-on-windows
- topng.exe (a good utility for converting files)
http://www.bcheck.net/apps/
http://www.bcheck.net/apps/topng.htm
- CmdCaptureWin.exe
http://www.ducklink.com/free-command-line-screen-capture.php
- FreeSSHd (a nice SSH and Telenet server, if you dont already have one)
http://www.freesshd.com/
All of them are freeware and easy to download from the internet.
But i add them to this instructable too.
- CmdCaptureWin.exe
Step 2: The Scripts Aka Cmd Files
We gonna write 5 cmd files (3 for screensot and 2 for the webserver logs) and one html file, all with the help of the old and trusty notepad.
cap.cmd - it makes a png screenshot with the help of scheduled task job
pic.cmd - it converts the png screenshot in a nice smaller jpg called bild.jpg
web.cmd - it starts the web server on port 8000 for 30 seconds to serve
the screenshot jpg, it accepts 2 command line arguments, first
argument, changes the runtime of the webserver to the seconds inputed
and the second argument is the port number.
web 120 - runs the webserver for 120 seconds on default port 8000
web 120 6000 - runs the webserver for 120 seconds on port 6000
log2html.cmd - it converts the webserver logs in html form
clearlogs.cmd - it delets the html logs and empty the log files
You need to run the server a second time to read the logs from the first
session.
OBSERVATION: PUT ALL YOUR FILES IN A SINGLE FOLDER THAT IS EASLY ACCESIBLE FROM SSH. (My are in C:\Bild)
session.
Step 3: Setup : Schedulded Task Job
First you need to setup the scheduled task like in the step by step picture tutorial that folows. We need to run the screenshot application troght scheduled task then SSH dont offer session interactivity, that results in a black screenshot or a 'stuck' screenshot program. But we can run a program that is part of windows that IS SESSION INTERACTIVE.
In the pictures from 1 to 11 it is described how to creat a schedulde task job that is with the following settings :
Type: Run Once
Time: 06.00
Data: 01.01.1980
what to run is CmdCaptureWin.exe
Follow the pictures and make all settings as in the pictures.
if you get the error message as shown ignore it and at advanced settings that opens when complet type your username.
Type: Run Once
Time: 06.00
Data: 01.01.1980
Step 4: Cap.cmd
Save this in cap.cmd
-------COPY UNDER THIS LINE-------
@ECHO OFF
schtasks /run /tn CmdCap
-----END COPY OVER THIS LINE -----
What dose this:
Run the scheduled tasks job called "CmdCap" (we made this job)
@ECHO OFF
What dose this:
Step 5: Pic.cmd
Save this in pic.cmd
@ECHO OFF
topng bild.png jpg
What dose this:
@ECHO OFF
topng bild.png jpg
What dose this:
Step 6: Web.cmd
Save this in web.cmd
@ECHO OFF
Echo.
Echo web.cmd [Timeout in seconds] [Port]
Echo.
SET Timeout=%1
SET Port=%2
IF [%1]==[] SET Timeout=30
IF [%2]==[] SET Port=8000
start TINY.EXE "%CD%" %Port% /nowait
Echo Webserver at port %Port% for %Timeout% seconds.
"%cd%\sleep.exe" %Timeout%
taskkill /F /IM TINY.EXE /T
What dose this:
define to default variables with default values 30 and 8000
run server on port %Port%
wait for %Timeout% seconds
closes the server process
@ECHO OFF
Echo.
Echo.
SET Timeout=%1
SET Port=%2
What dose this:
Step 7: Log2html.cmd
Save this in log2html.cmd
@ECHO OFF
ECHO Y | del access_log.htm
ECHO Y | del agent_log.htm
ECHO Y | del error_log.htm
ECHO Y | del referer_log.htm
ECHO Y | ren access_log access_log.htm
ECHO Y | ren agent_log agent_log.htm
ECHO Y | ren error_log error_log.htm
ECHO Y | ren referer_log referer_log.htm
What dose this:
delete html converted log files created before
convert log files to html files
@ECHO OFF
What dose this:
Step 8: Clearlogs.cmd
Save this in clearlogs.cmd
@ECHO OFF
echo. >access_log
echo. >agent_log
echo. >error_log
echo. >referer_log
What dose this:
empty the content of the log files
delete converted html log files
@ECHO OFF
echo. >access_log
echo. >agent_log
echo. >error_log
echo. >referer_log
What dose this:
Step 9: How to Use All This ?
Connect with putty or your SSH client to the server.
First run cap.cmd
Second run pic.cmd
Third run web.cmd
How to access the image ?
Open your web browser (Google Chrome, Firefox, Internet Explorer, ...) and type
http://125.125.125.125:8000
Where 125.125.125.125 is the hosts IP and 8000 the port number.
The IP is the same you typed in putty.
Hope you enjoy all this and helps you too.
PS
Yes, i know that exists VNC servers and that you can grab only a picture but VNC is not encrypted and if you need only a screenshot, my method is faster.
First run cap.cmd
Second run pic.cmd
Third run web.cmd
PS
