Introduction: How to Get the Energy Sword in Halo 1
instructions on how to get the energy sword in halo 1
Requirments:
Halo PC(u can use trial if u want)
Halo Map Tools (if it doesnt work download Microsoft Network frame)
Halo Map Tools plugins (I got mine from a MA5C Assault rifle at filefront)
since this is not my sword Full credit goes to echoranger449 from Filefront
pros:
Good looks
Perfect crosshair (Rectile)
cons:
the crosshair will show in all maps
no custom sound yet
if u have a mac the sword will be purple like mine is
Requirments:
pros:
Good looks
cons:
no custom sound yet
Step 1: Step 1, Difficulty: Medium.
Go to: http://halo2.filefront.com/file/Cryosis_Day;95305
then download it
when its done make a folder called "Backups" in: C:Program Files/Microsoft Games/Halo/Maps.
Then copy these files: Bitmaps.map, Sounds.map, ui.map, and bloodgulch.map.then paste the files into the Backups folder. Ok now go out on the desktop and make a folder called: Halo. then open the folder, Make a new folder called: Energy Sword. still with me? if your not then comment if you are still with me then good. ok now open the folder u downloaded (Cryosis) ok then double click: Install_Cryosis.exe now install it when its done open Halo Map Tools then open bloodgulch.map then click on: [bmp]Bitmaps tag then scroll down til u see Plasma Rifle click on it you should now see a picture of the color of the gun(should be the color of an energy sword) press the Extract button. are you still with me? if your not comment and il give easier instructions. Now extract that into Halo/Energy Sword. ok now close the bitmaps tag go into the tag called: [mod3]Model PC ok now see Plasma Rifle/fp/fp click on it you should now see a pic of the model (Energy Sword Model) press "Extract Model" extract it at: Halo/Energy Sword and then close the map . Yay the longest step is over!
then download it
Step 2: Step 2, Difficulty: Easy-Medium.
now go into Program Files/Microsoft Games/Halo/Maps/Backups copy those files and paste them into Maps(if a window comes up that if you want to replace files select "Yes to all") ok now Halo is back to normal but we can still get the energy sword without the mod open Halo Map Tools and open a map do not do bloodgulch (example b30/ The Silent Cartografer) now open the bitmaps tag find Plasma RIfle press Import then a window should come up press the Desktop Button then open Halo/Energy Sword then you should see a file double click it and Vola u get a color of an Energy Sword.
ok now close the bitmaps tag then open the Model PC tag the find plasma rifle/fp/fp press import model then a window should come up press the desktop again and find halo/energy sword then u should see a file double click it and then save
Step 3: Step 3 (Plugins Required)
this is sorta a difficult step find the weapons tab then find plasma rifle then find something that says: heat(checkbox unchecked) then u should see alot of heat stuff change it all to 0 save and close the weapons tab then go to damage tab find plasma rifle/melee find the damage some should be in this order:
40
50
60
change it to:
150
150
150
save it then thats it
40
50
60
change it to:
150
150
150
Step 4: Step 4(if U Want Rectile)
NOTE if u want the rectile do not backup your bitmaps install it then open halo map tools and open bloodgulch find the bitmaps tab then find ui/hud/bitmaps/combined_rectiles
extract the 5th one save and close the map choose a different map then open the same tag and do the whole thing again exept import it instead of extract save and ur done.
Step 5: Using It
this is much more easier then getting a pelican and dont go trying to kill an elite with an energy sword.
First go and kill an elite with a plasma rifle it will look like a plasma rifle but when u pick it up its an energy sword you can only shoot once then it will overheat and will never stop overheating unless u pick up another gun heres a list what this sword can kill easily:
Hunter: 1 - 2 hits
Jackal: 1 hit
Elite: 2 hits (if u hit him in the back its 1 hit)
Combat Elite(flooded elite) 2 - 4 hits
combat human 1 - 3 hits
fat flood guys 0 - 1 hit (if u bump into him he will trip and explode lol)
Hunter: 1 - 2 hits
Jackal: 1 hit
