Introduction: How to Hack Digital Infra Red Switch to Make Analogic IR Distance Sensor
You will need a static digital (0-1) IR switch
An Arduino
And See the video :))
Idea:
The idea is to change the emitter voltage and detect distance based on map function ...
Code
#define pIRR 10
#define pIRE 3
//speed of detection Ms
int Captspeed = 50;
void setup() {
Serial.begin (9600);
pinMode(pIRR, INPUT);
pinMode(pIRE, OUTPUT);
pinMode(11, OUTPUT);
float voltMin =1.9;
float voltMax = 5;
void loop() {
float voltage = voltMin;
int steps = 0;
while(voltage <= voltMax)
int av = ConvertVoltToAnalog(voltage);
voltage += 0.1;
analogWrite(pIRE,av);
delay(5);
int comingIR = digitalRead(pIRR);
delay(1);
if(comingIR == 0)
digitalWrite(11,HIGH);
voltage = 99;
break;
digitalWrite(11,LOW);
steps ++;
delay(25);
float distance = 99;
if(steps !=0 && voltage == 99)
distance = map(steps,1,31,-4,31);
Serial.print("Distance To Object = ");
Serial.println(distance);
else
Serial.println("Nothing detected!");
delay(Captspeed/2);
analogWrite(pIRE,0);
delay(Captspeed/2);
int ConvertVoltToAnalog(int voltage)
int res = 0;
res = map(voltage,0,5,0,255);
return res;
An Arduino
Idea:
Code
#define pIRR 10
#define pIRE 3
int Captspeed = 50;
void setup() {
float voltMin =1.9;
float voltMax = 5;
void loop() {
int steps = 0;
voltage += 0.1;
delay(5);
delay(1);
if(comingIR == 0)
voltage = 99;
break;
steps ++;
delay(25);
else
delay(Captspeed/2);
delay(Captspeed/2);
int res = 0;
return res;
