How to Hook Up a Xbox 360 to a PC Monitor
Intro: How to Hook Up a Xbox 360 to a PC Monitor
If you want to hook up your Xbox 360 to your computer monitor because your TV is small or the picture quality is terrible, I will show you how. Is it an expensive job you may ask, Nope, Only $10 in parts from my local Radioshack. Please leave a comment so I get feedback
Update 3/4/09: New final pictures added.
Update 10/26/09: New Comments Added To The Pictures!
COPYRIGHT RESPECTS AND CITATION FOR THIS INSTRUCTABLE IS AS FOLLOWS
All in-game images are copyright of Bungie Studios, Activision, Microsoft, and Infinity Ward.
Halo 3 is a copyright work made by Bungie Studios, USA and Microsoft, USA.
The Call of Duty trademark is an original work by Activision and Infinity Ward, USA
STEP 1: Time to Find the Parts!
Before you start this project, you need a few things.
1. Xbox 360 Console
2. LCD or CRT Computer Monitor. ( Just for a quick FYI, Mine is a 20 inch Dell wfp)
3.Stereo female RCA to male 3.5mm Cable Which Is needed to get the sound from your computer speakers.
4.Xbox 360 VGA HD AV Cable if your monitor does not have a component port. (mine does so no pictures)
PLEASE READ: to get the part 3 & 4, go to amazon.com or Radioshack ( I got my cables at Radioshack for $10)
1. Xbox 360 Console
STEP 2: Hook Up the Xbox 360 VGA HD AV Cable
If your monitor has a composite port, skip this step!
Steps:
1. Unplug The Old Cable From Your Xbox 360.
2. Unplug the VGA cable out of your monitor.
3. Insert the AV Connector on the Cable Into The Xbox 360.
4. Screw The VGA Cable Into Your Monitor
NOTE: I have a composite cable on my monitor so there will be no pictures for this step. I am sorry.
Steps:
STEP 3: Hook Up the Speakers
Now turn on your Xbox and your monitor. You will notice something immediately, WHERE IS THE SOUND! Luckily, the hook up is dead simple.
1. Unplug your speakers from your computer. ( If you do not know what the speaker cable looks like, it is green)
2. Take out your stereo female RCA to male 3.5mm
3. Plug the RED & WHITE plugs on the VGA cable into the stereo female RCA to male 3.5mm
4. Plug the speaker plug ( green plug ) into the stereo female RCA to male 3.5mm
Look at the pictures below for more detail
STEP 4: Testing Time!
Turn on your Xbox 360, Monitor, and Speakers. It Works!!!!
If it does not work please look over the steps. If it somehow still does not work, PM me.
STEP 5: Have Fun
Play Call of Duty 4, Halo, or Rock Band because you have successfully finished this project.
344 Comments
caroliefield 3 years ago
I don't have pc speakers, but I have a bluetooth speaker, could that work?
trentonshower 5 years ago
a do19ws Samsung moniter wont turn on and the power is flashing
do you have an idea of what to do
KgosiM1 5 years ago
kenzie73120 11 years ago
This site has many different audio/video cables to fix your problems. The prices are pretty well listed on the site too! I hope this can help your issue!
MohsenI3 8 years ago
HaroldDS 8 years ago
My monitor does not have speakers, yet I do have two different sets of computer speakers. The monitor is only VGA. I believe that would change my XBOX 360 setup.
I bought what I thought was the converter I needed from Fry's Electronics, but it turns out to be VGA input to HDMI output. It obviously doesn't work. No wonder it was returned.
I am still trying to find what I need.
KooshaM 8 years ago
breanna.baurley 8 years ago
http://www.amazon.com/gp/product/B003LVDWOQ?psc=1&...
I found that one on Amazon. It's called a
paulhud 8 years ago
I have a xbox360 and want to connect a pollyview ver 293 lcd monitor via hdmi to dvi-d.
The xbox will not see the monitor. Any ideas anybody.
Electronickid4314 10 years ago
faue 8 years ago
Ortun 8 years ago
My monitor has built in speakers, will I just not be able to sounds or...?
esewei92 8 years ago
the monitor will probably only have vga or dvi but get a vga to hdmi and connect the xbox to the monitor throught the hdmi and im pretty sure it will work with sound
if you connect through hdmi yea i think so
unilank 9 years ago
hey guys,
can i use the following instead of what is being recommended
1) 3.5mm female Stereo Jack to male RCA plugs cable
2)iConnect World HDMI Male to VGA female Audio HD video Cable Converter Adapter .
(I own a XBOX 360 E and an AOC E1670SWU LED Monitor)
AshtonA 9 years ago
ok so i have the newest xbox 360 slim i also have a windows 8 desktop. im not sure what cords to use to hook them up. plz help thx
AshtonA 9 years ago
aj-salaris 10 years ago
BenT2 9 years ago
Hi,
How did you make laptop screen as TV screen? Can you name the wires and tell the steps
aj-salaris 9 years ago
Yes, gladly. First of all you will need a VGA cable or an HDMI cable. HDMI is much newer and usually easier, but some laptops/TV's only have one of them. You can look online about what each one looks like. Now you find the plug on both you laptop and you tv and plug them in accordingly. Your laptop might blink at first, I know mine does. I use windows 7 so you might have to find better instructions otherwise, but these are the pretty broad instructions. Go to your laptop and right click on your desktop background. Then find and click on "Screen Resolution" in the drop down menu. Here is where you should be (Check enclosed image). Your laptop should recognize that you have a monitor or TV connected. Click the drop down menu next to Display and find the name of your monitor or TV. As you can see, mine is an ASUS VE278. Now you can play around with the settings. My current settings say that when I have a VGA plugged in, it will black out my laptop screen and make the monitor my main desktop. You can change up things like the Orientation, multiple displays (this means you can have more than one screen, like maybe if you wanted to pull a video up on your laptop, then drag it on to the monitor screen), etc. If you have any trouble feel free to contact me again.
~AJ
