Introduction: How to Import CD Tracks to Your ITunes Library?
If you have a music CD which you bought long ago and never had the chance to import to your iTunes library, this easy step-by-step guide will show you how.
If you read this article till the end, you might also be interested in how to:
Remove iTunes duplicates
Step 1: Open Your ITunes and Insert Your Music CD
Step 2: On the Prompt Click "Yes"
iTunes will prompt you after a moment whether you want to import the contents of the inserted CD to your iTunes library. Click on the “Yes” button.
Step 3: If There Is No Prompt...
If iTunes does not give you the prompt message, you can select the newly appeared CD icon from the left-hand-side pane, and select “Import CD”
Step 4: Import Settings (optional)
You can change the file format and the quality level in which the tracks will be encoded while being imported to your iTunes library. I would advise you to leave these values as they are if you do not know what to change.
Step 5: Import Process
iTunes will start importing the CD tracks to your iTunes library. This may take a while.
Step 6: That’s It!
After the import process finishes, you will have all your CD tracks imported into your iTunes library.
