Introduction: How to Install a SATA CD-ROM Drive?
This instructable is teaching you how to install a CD-ROM drive inside a CPU. The steps were easy and clear. And it has high quality images for you easily understand.
Step 1:
Remove the CPU case.
Step 2:
Remove the drive bay cover where you put the CR-ROM drive.
Step 3:
Insert the CD-ROM drive inside the drive bay. Make sure to insert it slowly smoothly, or else it will get stock.
Step 4:
Fasten the CD-ROM drive with the locking mechanism, to let it steady.
Step 5:
Connect the SATA power cable to the CD-ROM drive.
Step 6:
Connect the other end of the SATA power cable to the power supply.
Step 7:
Connect the SATA data cable to the CD-ROM drive.
Step 8:
Connect the other end of the SATA data cable to the motherboard.
Step 9:
After installing the CD-ROM drive and the cables, close the CPU casing.
