Introduction: How to Install a TV Antenna or Aerial
Versión en español
Before you buy your antenna and spend your hard earned money you need to consider a few things. You need to find the type of antenna that you need, the location of your antenna, your budget, your skill level and the cost effectiveness of the project. Depending of the location of your home you may not benefit from getting your TV programming from a TV antenna if you don't get enough channels where you live or, if the channels available in your area don't appeal to you. Before you start you may want to search all the stations broadcasting where you live. An excellent source of information is Antennaweb.org. At antennaweb.org you can search stations in addresses located in United States and overseas territories and, it is a great tool to help you decide what to do next.
Step 1: Outdoor Antenna Versus Indoor Antenna
- Easy to install, almost right out of the box.
- Some have great receptivity wherever you place them in your home.
Some disadvantages of indoor antennas are:
- Some cheaper antennas have limited receptivity.
In contrast outdoor antennas have some benefits like:
- Choice of unidirectional or omnidirectional.
- Better and increased receptivity of digital signal.
- Usually located at the highest point on a structure, thus increasing reception.
- Choice of shapes and sizes. Some antennas look like arrows, some look like little satellite dishes, some look like grids and, some like flying saucers. The shape of the antenna is a result of its function. Unidirectional antennas look like arrows and some of the newer ones look like small satellite dishes. Omnidirectional antennas may look like grids or small flying saucers.
- There are many different ways to install an outdoor antenna: gable install, roof, wall or, chimney. There are different installation kits available in almost every hardware store.
The disadvantages of the outdoor antennas are:
- Unless you hire a professional installer, it requires you to climb ladders, use power drills and, walking on your roof. Caution should be taken to not install your antenna too close to electrical wires or, during wet, stormy or, snowy weather. Always observe the maximum weight capacity on your ladder, do not use unstable ladders and, never overextend your arms trying to reach anything.
- Installation of an outdoor antenna requires grounding to discharge any electrostatic potential that will attract lightning.
Step 2: Materials
- Antenna of your choice.
- 75 ohm to 300 ohm transformer (should come with new antenna)
- Mounting kit (braces, u-bolts, etc.)
- Mast (antenna must be 10 feet (3.04 meters) above roof, you will need a 12 feet (3.66 meters) mast or two 6 feet (1.83 meters masts if you add a rotator)
- UV resistant outdoor coaxial cable (100 feet, 75 feet, 50 feet or 25 feet depending on your configuration with ground wire)
- Grounding block.
- Splitter (2 way, 4 way, etc., depending on how many TVs you want to connect).
- One digital converter for every TV connected to the antenna.
- Antenna rotator (optional, only if you pick an unidirectional antenna).
- Hammer drill (for cement block or brick walls) or regular drill (for wood panel).
- Masonry or regular drill bits.
- Masonry or wood screws.
- TV signal booster (optional).
- Ty-wraps.
Step 3: Antenna Installation
Assemble the antenna on the ground. Secure all bolts and nuts and connect the transformer to the antenna if the antenna comes with the transformer. If the antenna comes with a coaxial connector outside the plastic casing simply connect the outdoor coaxial cable to the antenna. In some models the transformer is already built-in. Follow the manufacturer's instructions.
Carefully select the location of your aerial. Do not install too close to electrical wires or tree branches. My antenna has been installed on the opposite side of the house that, has the electrical wire coming from the service transformer. You may need someone to help you hold the antenna while you secure all the u-bolts to the braces. Make sure that the antenna is at least 10 feet above the peak of your roof. Also the nuts that come with your mounting kit will have washers that will not creep out. Make sure to tighten them.
Once the antenna is in place, secure the cable to the mast using Ty-wraps. If you have a rotator, allow about a 2 feet loop of enough cable between masts. When the rotator gyrates the antenna while searching for more stations the coaxial cable might be pulled and stretched. It is very important to allow the cable not to be stretched by the action of the rotator.
You may want to disguise the coaxial cable the best you can for aesthetic reasons. I have hidden the coaxial cable behind the gutters. Use your imagination.
Next, connect the coaxial cable to the grounding block or the splitter depending on your configuration. In my case I connected the cable to a 4 way splitter and connected three coaxial cables to a grounding block that would accept the three segments of coaxial cable (see picture above). One of the segments went to my upstairs bedroom, the second entered the basement to come out of the living room floor and, the third is kept with a TV in the basement. Now I can watch the news anywhere in the house.
Step 4: Can I Use My Old Antenna and Still Enjoy High Definition on My TV?
The answer is yes. You can enjoy HDTV with an old VHF/UHF antenna. According to the Antenaweb site you can still use VHF to receive channels of the 2-13 range.
The Very High Frequency (VHF) band is the segment of the television broadcast band covering channels 2 through 13. The Ultra High Frequency (UHF) band is the segment of the television broadcast band covering channels 14 through 83. Currently, the vast majority of TV stations broadcasting in digital are using UHF (14 and up) channels to do so. This is not due to any technical requirement of digital broadcasting, however. It is mostly because the UHF channels were more likely to be available in most markets. Eventually, after the digital transition is complete and TV stations no longer need to broadcast in analog, they may switch and use their current analog VHF channels for digital instead. Antennas that receive UHF stations only and ones that receive both VHF and UHF are available. If you are fairly certain you won't want to get any lower channels in the VHF 2-13 range, you could purchase one that is UHF only.
Also the How Stuff Works site answers the same question:
There is no need to buy expensive equipment to enjoy HDTV as long as your TV is HD and is connected to a reliable antenna. Like it can be appreciated in the picture above, my antenna is a VHF/UHF and I am able to receive on my LCD screen channel 8.1 and 8.2 in high definition.An antenna - Depending on your location relative to the stations you want to watch, a set of rabbit ears might do, but you might need a rooftop or attic antenna. You can buy an antenna that's specially made for digital signals, but any reliable VHF/UHF antenna will work.
ShopBot Challenge
14 Comments
10 years ago on Introduction
Since digital broadcasting replaced analog signals, I assume you are using the UHF section of the antenna, even though it also has a VHF section. Did you need to do anything special to guarantee the aim of the antenna toward the broadcast tower?
I have a VHF/UHF unidirectional antenna. I also installed a rotator that allows me to change the direction of the antenna. The rotator is powered and controlled remotely via another cable to a control box in your room. In my search I also found a direct approach with a crank in the attic. I posted the picture in case someone dares do the same thing.
Thanks for the response. My parents had a Tennarotor (brand name) back in the 1950s and 1960s. I had forgotten about them. I have not had one since. I once saw someone's home brew crank setup. I remember one person being on the roof aligning the antenna while someone else was near a window with the TV in view shouting back and forth when the picture was good.
Question 1 year ago
Hello. I took down my old antenna from the roof. I would like to identify all the parts. I mean, which section of the antenna is VHF? Which is UHF? And what section of it is FM? I guess, I would need to replace all the 75-300 ohms converters for new ones, as well as the coaxial cable. Everything is toasted since antenna has been on the roof for over a decade or more.
The black pieces or isolators are also toasted. But with some glue I can fix them... Any recommendations or suggestions are welcome.
Thanks!
5 years ago
How do I connect a new wire to my outdoor antenna? It's an older one
5 years ago
My outdoor wire is short. What can I do
5 years ago
new single house to flit we. however satellite tv antenna being to fully setting making how?
6 years ago
Thx, very clear explanation.
6 years ago
The benefits of outdoor antennas are pretty impressive. I agree with you, some indoor antennas don't have good receptivity. That's exactly the reason we want to get an outdoor one. It offers way more options! http://www.marsdensantennas.com.au
6 years ago on Introduction
someone has cut my outdoor wire how do i reconect it back up to put it into my freeview box
Reply 6 years ago on Introduction
you will have to get a new wire
7 years ago on Introduction
This is a very useful article. There is a similar article about tv aerials problems in another satellite and aerials installation blog (www.asltd.co.uk) that I would like to share with you. :)
8 years ago on Introduction
It is very useful information about tv installs at home. I love those tips while i am using antenna but i think so as soon as possible will get satellite services
9 years ago on Introduction
Thanks for sharing this very useful info.
