How to Kick Start a Motorcycle.
Intro: How to Kick Start a Motorcycle.
Kickstarting a motorcycle isnt as easy as it looks.So ive created an instructable to show you how to start two different bikes.
STEP 1: Put the Bike in Neutral.
Depress the clutch and shift into first gear.Then gently raise the shifter until you feel a slight "click" if you can move the bike around its in neutral
STEP 2: Turn the Petcock.
Set the petcock to on.
STEP 3: Choke.
turn on the choke if your bike has one.It will be located on the carb.
STEP 4: Start It!
pull out the the kick starter and quickly push down until the bike starts.Rev the bike a few times then turn the choke off rev it a few more times or until it will idle.
STEP 5: The Beast.
If you have a larger bike like a 200 or 450 (the honda 150r also applies) The bike ma have a hot start.Basically it reduces compression so its not as hard to start.On the 450 you couldnt start it without the hot start.So follow the same steps as the othe bike but while kicking the bike hold thee hot start until it fires up.It should be located over the clutch.Ride safely and have fun!
36 Comments
whipit85 15 years ago
wobbler 12 years ago
However, big bikes, especially big single cylinder bikes, are hard to turn over as at the top of the stroke there is a lot of back force from the compression in the cylinder. So, big bikes have compression release levers, which lift the exhaust valves slightly and make it easier to get the piston to the top of its stroke. The lever is then released and the bike then kick started from the optimum position..
mattoverby 3 years ago
And not all bikes have decompression valves.
wobbler 3 years ago
takboilaw 12 years ago
This way you are sure you can control the bike by holding on the handle bars while depressing the brake.
This picture being shown if the side stand become unstable and your bike is bigger than you can handle there is a great possibility it will fall on you.
Kicking it this way for me is not safe your left leg and your body is not properly align/positioned. When you kick it it will tilt to the right and bounce back to the left the Bike.
So For me I rather seat on the bike straddle depress front brake kickstart it with your right foot.
oakironworker 13 years ago
miniminitrck 14 years ago
kabamba-t 5 years ago
indian741 11 years ago
I always kickstart without this,
I got a suzuki drz400 and a Armstrong mt500
Just get the piston to TDC ( the part where u hear it click )
Then 1 hard kick and i should run without this lever .
SteveD122 7 years ago
I had an MT500 (rebored to 560) that i never used the decompression on too...just little light taps on the kickstart until you felt the "back an forth" resistance rock of TDC, then, whammy, a full kick and it sparked into life. It didn't help that the thing weighed a Tonne and had a lefty hand kickstart though..even after i rebuilt it as 555.
Although I always used it on my road-legal '79 XT500 though because it had a nasty habit of kicking back...and when you got a kickback from that thing it would dislocated your kneecap ( it actually did once...lesson learned and never again did i try starting it without decompression! )
muddog15 11 years ago
Haazi 11 years ago
The best way of doing it would be as most of you have mentioned push down on the kick start untill you find top dead center or when it gets to hard to push down, release the kick start lever so that it return to the top then use the decompresstion just to get over the compresstoin stroke.Then just kick it.
I have an kniee injury on my right leg so I had to learn to kick start my XR 500 with my left leg while standing next to my bike.
Aron313 12 years ago
railisammilovesnathansykes18 12 years ago
daveand5 12 years ago
My cousin and I came out of a bar, got on our bikes, Jack had to kick his Norton over. par for the course it kicked back and he hurt his ankle so he couldn't kick it again. This guy called Tiny, for obvious reasons was standing there, so Jack said, "Tiny, kick it over for me, would ya"
Tiny stepped up, gave it one kick and knocked it over to the ground and said "like that Jack"
Guess it pays to use correct language sometimes, lol
yorniloc 12 years ago
