Introduction: How to Log Input With Batch Files
Are you creating a very dangerous batch file, and you want to know when people use the specified commands? This is the instructable for you!
Are you making a login-based AI that listens to your commands, and you want to know when people login? This is the instructable for you!
What you need:
your batch file put into a folder
nothing else in the folder
time to type a few lines of code.
You may have a shortcut somewhere else on your PC.
What you need:
Step 1: How Do Add Logins.
This isn't originally my code (I did edit some of it), but here is the code to add logins:
If you can see, when you sign up, it creates a file named %newname%.bat, and another named %newname%.logs.txt. %newname% is the username you give when you sign up. When it creates the .bat file, in it stores the username and the password. I created the logs.txt file, and in it it logs whenever you someone does a command in which it is programmed to record. Say, when you login, it will put into the logs: Logged in %time% %date%. These items will be placed into the same folder as your batch file, along with another folder named cmdacoBin. You can ignore this folder.
@echo off
:AccountSetUp
echo [1] Log In
echo [2] Sign Up
echo [3] Exit
echo.
set /p op=
if %op%==1 goto 1
if %op%==2 goto 2
if %op%==3 goto 3
goto error
:2
cls
echo Sign Up
echo ======================================
echo.
set /p newname="Enter new username:"
if "%newname%"=="%newname%" goto inputname
:inputname
cd "%userprofile%\documents"
if exist "cmdacoBin" goto skip
if not exist "cmdacoBin" goto noskip
:noskip
md "cmdacoBin"
goto skip
:skip
cd "%userprofile%\documents\cmdacoBin"
if exist "%newname%.bat" goto namexist
if not exist "%newname%.bat" goto skip2
:skip2
echo set realusername=%newname%> "%newname%.bat"
echo Signed Up: %time% %date%> "%newname%.logs.txt"
goto next
:next
echo.
set /p pswd=Enter new Password:
if "%pswd%"=="%pswd%" goto inputpass
:inputpass
echo set password=%pswd%>> "%newname%.bat"
goto next1
:namexist
echo.
echo The entered username already exists.
echo Press any key to return. . .
pause >nul
goto 2
:next1
cls
echo Clevernot Accounts
echo.
echo Your account has been successfully created!
echo.
ping localhost-1>nul
goto Start
:1
color 07
cls
echo Clevernot Accounts Log In
echo.
Set /p logname=Username:
if "%logname%"=="%logname%" goto 2.1
:2.1
echo.
set /p logpass="Password:"
if "%logpass%"=="%logpass%" goto login
:login
if exist "%logname%.bat" goto call
if not exist "%logname%.bat" goto errorlog
:call
call "%logname%.bat"
if "%password%"=="%logpass%" goto logdone
goto errorlog
:errorlog
color 0c
echo.
echo Username or Password incorrect.
echo Access denied.
pause >nul
goto home
:logdone
cls
goto LoggedIn
@echo off
:AccountSetUp
echo [1] Log In
echo [2] Sign Up
echo [3] Exit
echo.
set /p op=
if %op%==1 goto 1
if %op%==2 goto 2
if %op%==3 goto 3
goto error
:2
cls
echo Sign Up
echo.
:inputname
:noskip
md "cmdacoBin"
goto skip
:skip
:skip2
goto next
:next
echo.
:inputpass
goto next1
:namexist
echo.
pause >nul
goto 2
:next1
cls
echo.
echo.
goto Start
:1
color 07
cls
echo.
:2.1
echo.
:login
:call
goto errorlog
:errorlog
color 0c
echo.
echo Access denied.
pause >nul
goto home
:logdone
cls
goto LoggedIn
Step 2: How to Make the Batch File Record Commands.
It only records commands when you tell it to.
Say you wanted to record when a player Logs out, you can type (into your batch code)
echo Logged out %time% %date%>> "%logname%.logs.txt"
This would type into your file named (in example) HoweYouDrewin.logs.txt
In it it would say (in example) Logged out 4:09PM 02/13/2013
Make sure you put exactly as it says on top, or it will get screwed up.
if you put:
echo Logged out %time% %date%> "%logname%.logs.txt"
This code only has one (>) in it, and if you were to put only one in, it would wipe the whole text file, and start from scratch.
>=wipe, rebegin
>>=continue from where it left off
If you're confused, this is what it would look like in context:
@echo off
:Start
cls
set /p logout= Would you like to log out?
if %logout% == yes goto Logout
if %logout% == no goto Start
goto Start
:Logout
cls
exit
if you put:
>=wipe, rebegin
@echo off
:Start
cls
goto Start
:Logout
cls
exit
Step 3: How to Add a Wrong Password Identifier.
if you want to give someone 3 chances to get a right password, the code would look like thi
(this is the code after the batch file determines it's the wrong password, if your actually looking for the identifier, find it on the first step)
You can see that after 3 failed attempts, the account will be deleted.
If the person manages to log in after (in example) 1 failed attempt, all of the files for the failed attempts (%logname%.wrongpass.txt)
will be deleted.
@echo off
:w1
cls
echo Password Incorrect.
if exist "%logname%.wrongpass.txt" goto w3
if not exist "%logname%.wrongpass.txt" goto w2
:w2
echo First password failure occurred %time% %date%> "%logname%.wrongpass.txt"
ping localhost>nul
goto LogIn
:w3
if exist "%logname%.wrongpass2.txt" goto w5
if not exist "%logname%.wrongpass2.txt" goto w4
:w4
echo Second Password failure occurred %time% %date%> "%logname%.wrongpass2.txt"
ping localhost>nul
goto LogIn
:w5
if exist "%logname%.wrongpass3.txt" goto w7
if not exist "%logname%.wrongpass3.txt" goto w6
:w6
echo Third Password Failure occurred %time% %date%> "%logname%.wrongpass3.txt"
ping localhost>nul
goto LogIn
:w7
echo Your password has failed 3 times in a row. Your account will now be deleted.
del %logname%.bat
del %logname%.logs.txt
del %logname%.wrongpass.txt
del %logname%.wrongpass2.txt
del %logname%.wrongpass3.txt
echo Account deleted due to password failure %time% %date%>> "%logname%.del.txt"
ping localhost>nul
exit
:FinallyLoggedIn
cls
echo You have successfully logged In! All of your failed attempts (if any) will now be deleted.
pause>nul
goto Whatever
will be deleted.
@echo off
:w1
cls
:w2
ping localhost>nul
goto LogIn
:w3
:w4
ping localhost>nul
goto LogIn
:w5
:w6
ping localhost>nul
goto LogIn
:w7
del %logname%.bat
ping localhost>nul
exit
:FinallyLoggedIn
cls
pause>nul
goto Whatever
Step 4: Conclusion
This is my first instructable, and it was made on a Mac so I don't really have the pictures of the batch coding or anything. If you have any questions or suggestions for better coding, please comment below. After all, I did only come up with the code in about an hour during class, so I didn't really work out the bugs for some of it yet.
Thanks for reading!
Thanks for reading!
