Introduction: How to Make Easy Cellophane Wings
Here's a simple tutorial on how to make your own cellophane wings for your favorite costume!
Please check out my other tutorials, and vote for me int he Halloween Costume Challenge!
For more of my costumes please visit
www.littlewingsdesign.com/costume.html
My store
www.etsy.com/shop/fairystitchfactory
Photos by M.G. Norris Contemporary Photography
www.mgnorris.com
Step 1: Materials
What you'll Need!
1. Galvanized steel wire I tend to use 12 gauge.
Something stiff enough to hold it's shape but easy enough to cut and shape.
2. Floral tape, I tend to use black, but you can use different colors depending on the color wings you are making
3. Wire cutters
4. hot glue gun & glue
5. Spray bond sprayable glue, you can get it in the quilt section of the fabric store.
6. Cellophane roll you can get fancy with multiple colors.
7. heat gun, Iron or stove burner.
8. long matches, incense, or a wood burning tool.
Step 2: Making Your Frame
This part is really about your personal vision.
Cut a long strip of wire to be your main frame and bend it in a u shape,
Then bent the pieces to the desired shape of your main wings.
Cut strips of wire and bend to make your wing veins.
Wrap around them with floral tape and use the tape to secure them onto the frame.
Cover the whole ting over with the floral tape and you should end up with something like this.
(I design my wings to slip into a corset or a bra so I don't bother with straps,
but if you like to you can add loops onto the frame to pass ribbons through.)
Step 3: Cut Our Your Cellophane
Again this step is a bit about how you want your wings to look.
Lay your one side of your frame down and trace the basic outline of your wing
(don't fuss overly about the shape, you will refine it later)
Then cut out the shape.
You will need 2 sheets for each wing.
Step 4: Gluing on Your Cellophane
Lay down one of the two sheets of cellophane you cut out.
Spray it lightly all over with spray adhesive.
Lay your frame on top of it, and then carefully lay the next layer of cellophane over top of it.
(this part is a tricky bit, you may have to pull them apart and redo this step once or twice
to prevent folds and wrinkles between the layers)
Use your fingers to press the cellophane layers to each other smoothing in between the veins.
Step 5: Getting Fancy
If you want to get fancy with your wings, you can cut out some cool
shapes in a second color of cellophane, I like to do this before I
sandwich the layers together so the color is even on both sides.
apply them with the spray glue just like you would the cellophane layer, and then
add the second layer on top.
Step 6: Gluing Down on the Frame
Now trim the cellophane along the main wire frame so that you have about 1/4 to 1/2 inch
of cellophane hanging over.
Apply hot glue along the wire frame and fold overhang over the frame and glue down.
This will give you a nice finished edge.
(be careful not to let the glue get to hot, I burn my fingers frequently in this step.
Be careful!)
Step 7: Heat Gun!
Once you have the cellophane all glued lightly go over it with the heat gun, or iron.
This steps takes a bit of trial and error, if you heat it too much the cellophane it will
make holes and tear or pull too much. Be sure to hold it far enough away from the wings
to just shrink the cellophane tight to the frame. Do this on both sides of each wing.
If you are using an iron, put a light cloth between the iron and the wings.
Set the iron on low and go over the wings. I haven't had much success with this
method myself, but lots of people use it.
Step 8: Refining Your Shape
For this step, you can use incense, a long match, or I myself like to use a wood burning tool.
Burn the edges of your wings into a natural interesting looking shape, I like to burn some holes into the
wing itself to make them more interesting and fairy like myself, but it's all about taste.
Get creative and try new things.
Step 9: Finished!
tah dah
you have a wonderful pair of fairy wings.
From here you can get fun and creative. Add glitter, leaves flowers, ribbons,
whatever you like. You can also coat them with resin to make them more durable.
Your imagination is the limit!
My store
www.mgnorris.com
