Introduction: How to Make Rainbow Loom Triple Single Without a Loom
this is a very easy project so that you can make a beautiful bracelet without the loom
Step 1: What You Need
you will need 2 forks (plastic or metal), bands, s or c clip, and your fingers!
Step 2: Preparing Materials
Place the two forks back to back and hold them in that position until you complete step 5
Step 3: Color Choices
Take your first color
Step 4: Twisting Band
twist your first band and make it into a figure eight.
Step 5: Placing Bands
place a band in a figure eight across all of your fork pegs on each side
Step 6: Placing the Bands
Take your next color and put it on the last tongs going straight across.
Step 7: Placing the Bands 2
place a band straight across the two middle tongs so your forks look like the ones above.
Step 8: Placing the Bands 3
place your background color (the color you started with) below the second Colour so you have second color on top and first color on the bottom
Step 9: Pulling Over Bands
Image 1: Pull your band that is under your second color on both sides
Image 2: You forks should look something like this image now
Image 3: Add another layer of bands on each side
Image 4: Add another band under the previous layer in image 3 and pull the purple (in my picture) bands over on each side of the fork
Image 5: You folks should look something like this image
Step 10: What It Should Look Like
Keep adding layers of bands as in step 9
This is what it should look like along the way :)
Don't forget to pull it down every 1 or 2 layers!
Have fun!
