How to Make Spider Silk Thread
Intro: How to Make Spider Silk Thread
During the summer months, spider webs cover every corner, and every open space of my yard. These webs are humongous, the largest ones being about 5 feet wide. The webs I encounter in my garden are webs are from several kinds of Orb spiders. None of the spiders that build the giant webs in my garden are poisonous. This is lucky for me, because I have walked into countless numbers of webs.
I have also encountered many abandoned webs, which gave me the idea of harvesting these out-of-use webs for their silk. Having walked into so many webs, I know how unbelievably strong and stretchy their threads are. Spider silk, in fact, is the strongest fiber ever discovered. Spider silk is stronger than steel, for its diameter; that is, a thread of steel would be weaker than a thread of spider silk of the same size.
Scientists have been working on how to entirely artificially duplicate spider silk in the lab for a while, but have not yet been able to make the silk entirely without spiders. I have included some websites of some recent research on the subject at the end of the instructable.
In this instructable, I will show I how I harvested abandoned webs and turned them into threads that I could use to sew.
STEP 1: Understand Which Species Make the Right Webs
Where I live, in southern North Carolina in the USA, there are about four types of spiders that make good webs for collecting:
1) golden orb spider,
2) black and yellow orb spider,
3) crab orb spider,
4) orchard spider
All of these build large, regular orb shaped webs, with strong fibers. None of these spiders are dangerous, but I recommend avoiding their bites anyway, because it could be painful, and there may be those who are allergic to their bites. I have never heard of anyone being allergic to orb spiders, but it's not impossible. Also, if you got close enough to one of these spiders to actually get bit by it, you were probably seriously annoying it (I have actually poked a giant golden orb spider once to show my uncle that it was harmless).
Before collecting webs from any spider, please make sure you know what kind of spider it is. There are poisonous spiders in the USA. Outside the USA, I cannot speak with authority about the kinds of spiders, so you should do you own research about spiders before collecting their webs. Especially in Australia (home of the most poisonous spider in the world)! In the USA there are two web building spiders that have a deadly venom, and should be avoided at all costs:
1) The black widow (and brown widow) spider
2)The brown recluse
I have not seen these in my yard, but I have avoided their habitats on purpose. The picture I have of them are not mine, because I did not want to stick my face in them to take their pictures. Luckily, these spider's webs look completely different than the four spiders I mentioned earlier. While the four spiders I mentioned all build webs in the open, above ground, and in regular orb shapes, the poisonous spiders build irregular webs in piles of wood, rocks, bricks, and other things. These spiders are often found in garages, for instance, or firewood piles. I will say it again that these spiders are very dangerous! If you are bit by one ever, go to the emergency room!
I have included pictures of the spiders I mentioned, and their webs.
3) crab orb spider,
4) orchard spider
2)The brown recluse
STEP 2: Find Abandoned Webs
Collect only abandoned webs for spinning into thread. Not only is it nicer to the spiders, who are excellent predators of evil bugs such as mosquitoes, it prevents a chance encounter with a spider, whom you do not want to piss off. Certain spiders will build new webs everyday, such as orchard and crab orb spiders. Others, such as the yellow orb spider will maintain the same web as long as possible, sometimes building on new additions, and making humongous multi-story webs. Only when a yellow orb weaver spider decides to move to a new spot does it abandon its web.
Its not that hard to tell if a web is abandoned -- there is no spider in the web. Be careful, though, because it could be hiding off to the side where you don't see it at first.
STEP 3: Collect Webs
To collect webs, I first snagged one side of the web, and carefully twisted the web, carefully pulling off silk threads from the leaves, until I had a the fibers in a length. I avoided breaking any threads whenever possible, in order to keep the original threads as long as they could be, before having to twist on a new length of silk.
I then wound the length of silk on a smooth stick (the stalk of a lily) temporarily, while I gathered more silk.
STEP 4: Clean and Untangle the Silk
The silk from old spider webs will inevitably have things such as leaves, twigs, dust, and most often, leftover insect parts. These will need to be cleaned out of the silk. To do this, use a pair of tweezers and extract the debris and insects, all while trying not to break any of the fibers.
Next, in order to keep the length of the thread as even in thickness as possible, untangle the fibers and try to distribute the fibers from thicker parts of the length to the thinner parts of the length.
STEP 5: Combine Fibers
In order to combine the all the lengths of thread into two long lengths, I placed the lengths next to each other, overlapping by 2 to 3 inches on the ends, depending on how thick the fibers were. I then twisted them together in the same way that I twisted the fibers when I collected the silk.
I ended up with two lengths of silk thread, that I wound together in the next step.
STEP 6: Twist Thread
Next, in order to make the thread stronger, I twisted together the two long fibers I had twisted. I did this not in the same way I collected the fibers, as in the last step. I did this by winding the threads around each other individually. That is, first I crossed one fiber over the other, and then crossed the other fiber over the first fiber, and so on. This has to be done this way in order to keep the already twisted fibers together.
After twisting the whole length, I folded the length in half and twisted it again. It was too thin and weak otherwise. While spider silk is very strong for its width, it is incredibly thin, and needs to be strengthened by making it wider.
STEP 7: Wind Onto Spool
I had many many empty spools around, because my grandmother was an obsessive seamstress who had a house full (truly FULL) of sewing materials. If you don't have a spool, winding the thread around a piece of cardboard, or even a folded piece of paper will work as well.
As you can see, I have very little thread from this whole process. The reason for making spider silk thread is not for making a lot of thread, but is instead for having thread out of making the strongest, stretchiest material on earth.
Your seams could be stronger than the fabric itself!
STEP 8: Others Who Have Used Spider Silk, and Some of the Research Done on It
This is an exhibit on a piece of textile made entirely out of spider silk:
http://www.amnh.org/exhibitions/spidersilk/
These are all scientific articles on spider silk:
http://www.sciencentral.com/articles/view.php3?article_id=218392167&language=english
http://www.accessexcellence.org/WN/SU/spider.php
http://www.sciencedaily.com/releases/2010/05/100514151853.htm
This is also a scientific article on spider silk, but its about how scientist have combined metallic thread with spider silk. This could make the perfect conductive thread:
http://www.reuters.com/article/idUSTRE53M5OG20090423
112 Comments
cuiriosity_terminated-the-cat 2 years ago
rcbailey13 9 years ago
I someone wants to buy spider silk, I know of a location that has hundreds of webs. I do not know the current condition of the webs because they are not very protected from the elements. Tell how much you want and what it is worth to you and will see if we can make it happen. I do not know how we will determine the amount of web material we will end up with. You would also have to determine how you want it harvested- all in a ball or wound around something. Only about one in five webs were active last time I was there. I did not ID the spider making the webs.
jain.prafull05 3 years ago
SoA4 4 years ago
How can i get spider fabric or silk yard
KyarC 5 years ago
5 feet? so human size...
m_arahim 5 years ago
It is a great content!
Did you try Aquatic spiders?
Do you have any idea that I can collect their threads from water?
Regards,
Maryam
RG4rox 5 years ago
Would it be possible to turn this into a web for a web shooter?
Richmoney_Alex 7 years ago
Iis this spider silk sticky?
JasonE85 6 years ago
only specific spider silk is sticky it will be because of the threads that are not spokes, but it will not be sticky for long I love to play with this stuff it is not very sticky it also makes a negative charge. I am a spider man fan Search up Ben Reilly
how much can one of these threads hold in weight?
naklafshdmam 8 years ago
Everyone loves what you guys are up too. This kind of clever work and exposure!
Keep up the terrific works guys I've you guys to blogroll.
http://www.tfa2ol.com/naklasas.html
http://www.abyath.com
khairya 8 years ago
Here is my web-site
http://www.east-eldmam.com/
lukemarq 9 years ago
http://www.bbc.com/news/science-environment-16554357
Spidergoat
Never underestimate the mad scientists.
احمدع 9 years ago
A spider web farm would be awesome,but sadly spiders get cannabalistic when near other spiders. They are very aggressive.
http://www.dar-elsafwa.com/
e7trfseo 9 years ago
Would daddy long-leg spider webs work?
http://www.nirity.co
PaleHorseRider 9 years ago
You want to get webs that are strong even in a single strand.
Real grand daddy long leg webs' are weak and only gathered in small amounts.
JazmynA 9 years ago
Hi I'm doing a project where I'm building Spiderman's web shooters so I was wondering if you sell this thread or if you know where I can buy some. I'd really appreciate the help thank you.
Laserbeamtoast 9 years ago
