How to Make TRACING PAPER!!!
Intro: How to Make TRACING PAPER!!!
Sometimes we want to draw something but we cannot imitate it. So, I figured out a way to solve this problem. And the solution is simple, to have a paper that can trace everything. So I decided to come up with a tracing PAPER. with just very easy materials and steps.=)
STEP 1: Materials:
materials:
1. Bond paper
2. Oil
3. Paint Brush
4. can or container
1. Bond paper
2. Oil
3. Paint Brush
4. can or container
STEP 2: Step 1
Pour a little amount of oil into the can.
STEP 3: Step 2
dip the brush into the oil and spread it to the paper. But make sure the paper is not too wet. In case there is excess oil, wipe it with tissue or dry cloth.
STEP 4: Step 3
Put it in the sunlight. If there is no sun, you can keep wiping the paper or you just let it dry. Mine dried quickly because i live in the Philippines so it's so hot. whew
STEP 5: Step 4
Now you can trace any picture! And its so easy to trace because you can clearly see through them. i HOPE it became helpful to you! comment me if you liked it. ENJOY TRACING!!!
23 Comments
whisperonthewind 12 years ago
unknown24 10 years ago
PattyP17 7 years ago
I wonder if a tiny bit of silicone instead of oil would work. I buy tracing paper online in big rolls from Mister Art for making paper patterns for sewing whatever project I'm designing.
JuusoR1 8 years ago
I tried this method once ( I used canola oil, 'cause that was the only oil I had ). The results were fine otherwise - but there were a couple of problems: the paper left grease stains - and when I tried to tape it onto the table ( in order to hold it still while tracing) - the tape didn't stick on it. Any tips how I could avoid those grease stains and stick the paper onto table while tracing? I appreciate your answers.
joseph.dickson.77 8 years ago
You could avoid putting oil on the corners so it can be taped at the corners maybe... and put glad-rap/Plastic rap between your work and oil paper to avoid stains? (you could also use baking paper as tracing paper, I do that sometimes)
Nesmaat 8 years ago
PoljoS 9 years ago
can we put the oil in a normal a4 sheet?
mokaro 12 years ago
PonchoLibre 15 years ago
unknown24 15 years ago
RiddleOfSphinx 15 years ago
jtobako 15 years ago
klee27x 15 years ago
