Introduction: How to Make "Temple of Demise" Knex Ball Machine
This is Tornado 96 and this is an instructable for the first of my ball machines on this site. It is called Temple of demise. Feel free to ask questions and make comments. This ball machine uses a lot of pieces so i decided not to make a piece count. Sorry.
Unluckily I couldn't upload the video. Now that you've seen the pictures it is time to get started!
Step 1: The Base
This is a very important part of the model. Everything connects to this. I wonder if it would still work without it? I hope you notice how everything is placed
Step 2: The Tower's Base
This is where all the action starts. If you don't have red gears you can replace it with a yellow gears but you would have to fiddle around with the spacers. Please tell me if it is hard to understand the angle of the 3-D connectors.
Step 3: The First Receiver
The receivers are the paths that take the balls back to the chain lift. There are three in total.
Step 4: The Second Receiver
This is the second receiver which is placed on the left side of the construction.
Step 5: The Third Receiver
This is the third and last receiver. This receiver is placed on the left side of the construction.
Step 6: Main Structure - Bottom
The main structure keeps everything strong and steady.
Step 7: Maze and Wheel
The model is a bit boring. Lets start adding some of the elements! First build the maze and attach it. Then build the wheel and attach it.
Step 8: The Tower
This is where the chain takes the ball up to the top. This part also includes the path separators.
Step 9: Spiral Staircase
I'm not sure why i gave the spiral staircase a whole step. Anyway, all you have to dodo is make and attach and path 2 is complete.
Step 10: Main Structure - Right Side
Yet more structure. With out this the contraption might not work. This is the most boring part of this ball machine and there is still one left.
Step 11: Main Structure - Left Side
This is the last main structure. Hooray! After this part the rest of the instructable is building elements which is the fun part.
Step 12: The Chain Path and Pendulum Slide
Now that you've finally finished the structure it is time for the elements! These elements are both part of path 4. Look carefully for which spacers to use on the pendulum slide.
Step 13: The Orange Path
Your almost done. This is the orange path which is the main element in path 3. When your done just add the track. The length of the big ball factory tubing is long enough on the inside but you will have to add a bit to the outside. If the ball gets stuck at the end just move the tabbed connector a bit.
Step 14: Motor Attachment
In this model I used a plug in motor but I'm sure you'd be able to replace it with a any other motor or a crank if you don't have a motor.
Step 15: Chain Attachment
For this part you will need 75 chain links. Divide them into 3 sets of 25 chain links.
Step 16:
Congratulations! you have finished building temple of demise. Only the original red and yellow balls work. Any other ball will be too big for some parts of the contraption. If you built everything right it should never fall of the track. I hope you enjoy it!
