Introduction: How to Make Zinc Sulfate and Copper Out of Home Products!
Ah, so ye' wants to make Zinc sulfate and Copper? Follow this step to step and ye shall know how to make them!
You will need:
Weed killer (Copper sulfate ONLY, nothing else, must be blue)
Zinc metal (Old batteries ect.)
Water,
A beaker or cup,
Patience.
You may need:
Something to HEAT the solution, not boil.
You will need:
Water,
A beaker or cup,
Patience.
You may need:
Step 1: Starting Off...
Add the Copper sulfate into water, unless the is using weed killer (already in water)
Stir thoroughly...
Stir thoroughly...
Step 2: Then Add...
Then add zinc into the solution.
Step 3: Just Wait
A reaction will occur, this MUST happen.
The reaction should be like the one in the pic.
The zinc is being covered in what appears to look like, "hair"!
That is your copper!
You can heat the solution to speed up your process, that is optional.
Step 4: Final Touches...
Your solution should be transparent, if not, add more zinc.
Now, filter off the copper from the zinc sulfate,
You now have what you desired!
