Introduction: How to Make a C# Application Which Turns Your Screen Into a Cracked One
Step 1: Open VS and Create New Project
First of all , open visual studio and create a new project...
Step 2: Choose Template
now after you click "new project" , a new windows will open, in that window choose Visual C# option , which is on the left side of that window and when you click that "Visual C#" the templates will appear in front of you ! and after that choose "windows forms application.." template from them , which is on the top and then rename your application by clicking on the bottom line where there is already written "WindowsFormsApplication1" and when you click on it ! you will be able to write your custom name.
Step 3: Creating Form
Now that you have proceeded ! you shall see a blank gray coloured form.
On that form , add 1 label and 1 button.
add labels and button by searching the tool box which is on the left side of the screen.
just drag and drop ! the tool (/button/Label)
Step 4: Change Label & Button Properties
Now change the properties of the label and button !
for label i will make its AutoSize = False and FontSize = 40
for button i will make FontSize= 30
Step 5: Renaming the Label and Button
now to rename a button ! just head to properties and make its text to your custom text !
and do the same with the label !
Step 6: Add New Form
now add new windows form by clicking the "project" button on the top ! and then choose
"Add new windows forms...."
and then a new form will pop up !
Step 7: Now Change 2nd Form's Properties
Now to change the properties of the second form ! go to the properties !
and then search for Opacity option and then beside it you will see the percentage
of the opacity i.e Opacity 100%
now click that digits and then write 80% and then press enter.
and now change the form's borderstyle form Sizeable to None !
and then add the background image to that form ! the cracked one ! Download
(more in pictures)
Step 8: Add Label
now add 1 label to your second form !
and just make it empty ! and make it autosize to false and back color to transparent !
and put it on the top left side of your form but make sure you leave some space
so the user can click it !
(more in picture)
Step 9: Coding for Form2
now double click on the label1 and add this code
new Form1().Show(); this.Close();
Step 10: Coding for Form 1
now head to the form 1 and double click on the crack button and add this code
new Form2().Show(); this.Hide();
Step 11: Finish Now Publish (pt 1)
now its time to publish your app.
click on the build button on the top and click the publish button !
Step 12: Finish Now Publish (pt 2)
now when a pop up comes ! then it will ask for choosing the path where you want to save your application !
and then choose your specific path and then click the finish button ! directly !
Step 13: Setup
your application's setup will pop up and then you can install your application !
Step 14: How to Install
just double click the setup icon and proceed...
another option will come and that might scare you that ! the publisher is not verified !
But you shouldn't getscare ! just hit the instal button.
Step 15: Tadaa !!!
you will see, after you click the install button , your personally created application will open automatically !
so your application is done ! and you can have fun using it ! :)
THIS TUTORIAL WAS FOR ABSOLUTE BEGINNERS
follow me :-
